pontiac forums   pontiac forums
Go Back   Pontiac Forums > Past Pontiac Vehicle Discussion > Pontiac Montana Forum
Notices
Pontiac Montana Forum Discuss topics regarding the Pontiac Montana.
Pontiac Forum: why is my pontiac montana's check abs and check traction system lights always on?...
Reply
Thread Tools
  #1
Old September 9th, 2009, 10:35 PM
The Coach
Guest
Posts: n/a
...Two montana's same problem? This sucks
  #2
john t
Guest
Posts: n/a
the abs and the traction control lights come on because your sensors at the wheels are bad they need to be checked on a regular basis for dirt and such your first thing you should do is to have a diaq. done to find the bad sensor and have it replaced once that is done have them checked when you have your brakes inspected.
  #3
Old September 9th, 2009, 10:36 PM
kelly_f_1999 kelly_f_1999 is offline
Member
kelly_f_1999 is on a distinguished road
possible defect
type year model problems and can read about what others have said about that model of car
like
2008 pontiac montana problems
wil bring it up might be a recall or a model problem if you have two with same thing wrong
__________________
Web Services by Yahoo!
  #4
Mark F
Guest
Posts: n/a
The TCS and ABS are part of the same system. One fault defeats both and turns on the warning lights. Given the type of vehicle I'd say the first thing to look for is worn front wheel bearings, for which these are notorious. The Wheel Speed Sensors are part of the hub and bearing assembly in the front so a loose bearing will cause a sensor failure.
  #5
Old November 7th, 2009, 09:33 AM
dakilner
Guest
Posts: n/a
Quote:
Mark F is right on the money, have a diagnostic done. You can pay the dealer / local shop or simply go to a local auto parts store that has a code reader that will work on your van and have them pull the diagnostic code out of your computer (it is typically free service from the store to get you to buy your parts there) and look up the code on the internet. From this code you will be able to tell which wheel the sensor code is coming from. Whether the sensor is bad or the bearing the fix is the same, the bearing assembly must be replaced. If you are limber enough and have the proper tools the fix can be done in a resonable amount of time by you.
  #6
Old January 15th, 2011, 08:14 PM
bighank bighank is offline
Member
bighank is on a distinguished road
Have same problem but sensors appear good suspect module
Checked all my sensors and they appear to be good. I suspect the electronic module under the drivers side dash.
  #7
Old January 19th, 2011, 04:44 AM
ianmcdca's Avatar
ianmcdca ianmcdca is offline
Member
ianmcdca is on a distinguished road
These sensors are inside the bearing...they are not cleanable. Looking at them won`t determine which is bad....unfortunately you can`t go cheap on this. Have it scanned for ABS problems. I wouldn`t spend money on parts until I new which wheel bearing was responsible. On mine it was actually a rear wheel bearing.....very rare.
  #8
Old February 26th, 2011, 06:34 PM
Member
Theres another post that someone got the same symptoms with a BURNED OUT TAIL LIGHT
Can't believe that but with GM engineering who knows. I still suspect the module under drivers dash.
  #9
Old February 26th, 2011, 07:37 PM
ianmcdca's Avatar
Member
Quote:
I dont understand why you are doubting us??? I know it`s not cheap to have it scanned, but it`s also not cheap to replace a BCM either....
I own 5 GM vehicles. I`ve never yet had an ABS and Trac light on that wasn`t one of the wheel bearings gone bad (Ive had a problem with the ABS unit itself causing both lights to light). It`s possible that the BCM is defective, but until someone scans it, how will you know? If the BCM is bad it will show on the scanner. YOU CANNOT VISUALLY CHECK THE SENSORS IN THESE HUBS! They are 'sealed' inside the bearing assembly. Dirt on the outside if the housing means little.
Once again, a pocket/hand held scanner WILL NOT scan for ABS or SRS problems.
I hope you find your solution.
Ian
  #10
Old February 28th, 2011, 08:14 AM
planenut_2000 planenut_2000 is offline
Senior Member
planenut_2000 is on a distinguished road
I'm a ex GM dearship mechanic. Have it scanned! It is almost entirely a wheel bearing/sensor problem, or wire harness to the sensors.
Reply
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisements
DiabloSport T1000 Tuner
cars connected social network cars connected social networking app for ios cars connected social networking app for android
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
pontiacowners.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacowners.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2015 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
