I have a 1998 Sunfire GT 2.4l, 138,000 miles. I have been having a fluctuating idle problem, and slight loss of power that until just recently had NO code. i finally threw a p0300 misfire code, and am frustrated as to the problem.
i have replaced the TPS, MAP sensor, IAT sensor, and spark plugs, all within the last week...NO help.
I replaced the Idle air control valve, fuel pressure regulator, within the last 6 months.
and replaced the coil packs, O2 sensor, coil boots & plugs, cleaned the EGR valve (and replaced the gasket), within the last year.
i can't detect for a vacuum leak, and have run a few bottles of fuel injection cleaner through the system.
PROBLEM:
When i start the car and "coast" down the drive the idle fluctuates and then either "fixes" itself or coughs / sputters and dies, but i was not throwing a code. this happens when the car is cold AND sometimes when it is warm.
i also have been having an issue with hesitation / loss of power while driving...if i give it a little gas (gradual) it increases in speed. If i give it half pedal or more, it wants to bog down, then it may or may not kick in and go. this is not cool when trying to merge into traffic, or when that street light goes to yellow...
I am investigating the possibility of a bad ignition control module, clogged fuel injectors, a fuel pressure test, and i may clean out the EGR valve again, i also seem to get a lot of carbon in the carburetor area for some reason.
I also noticed that there was just a SMALL "puddle" of oil in the well of #1 spark plug when i replaced it this week...but that is near the oil fill cap, and maybe the oil change place spilled a little while filling.(hopefully NOT a head gasket)
i don't want to keep replacing parts that aren't solving the problem, just asking for any help / suggestions / ideas as to what to do, based on my symptoms
THANKS
PROBLEM:
THANKS
