Sign up to remove ads. We'd love to have you amongst our ranks! Just Click here!
pontiac forums   pontiac forums
Go Back   Pontiac Forums > Pontiac CUV and Van Forums > Pontiac Torrent Forum
Advertisements
cars connected social network
Notices
Pontiac Torrent Forum Discuss topics regarding the Pontiac Torrent.
Pontiac Forum: Equinox Rims fot Torrent?
Reply
Thread Tools
  #1
Old April 24th, 2018, 10:35 PM
08AWD 08AWD is offline
Junior Member
08AWD is on a distinguished road
My 2008 Torrent Rims look awful,
Some rims for sale from same
year from a Equinox are available..
would those fit/clear the inside brake caliper area?
I know the holes would match perfectly.
Thx!
  #2
Old April 25th, 2018, 09:44 AM
melsg5's Avatar
melsg5 melsg5 is online now
Senior Member
ADMINISTRATOR
melsg5 is on a distinguished road
The Torrent and Equinox are basically the same vehicle from two different divisions of GM. If the wheels are the same diameter and are factory they should fit.
__________________
1971 GTO 455 HO Ram Air
  #3
Old April 25th, 2018, 08:24 PM
Junior Member
Quote:
basically the same.. they should fit.
Thanks mel, buying all 4 of them later this week for $350,
will post the update when fitted.
  #4
Old May 9th, 2018, 02:57 PM
Junior Member
Update:
Finally got around to this Rim issue swap, this pic is
the Torrent Rim showing the clearance from the cross bar of the
Brake Caliper @ about 1/4".
The Equinox Rim snugly rubs against this bar.
Question:
If I throw on 2 steel washers per threaded stud
rotor as a spacer to bring it away, will this work?
Click image for larger version
Name:	Rim Caliper.jpg
  #5
Old May 9th, 2018, 03:23 PM
melsg5's Avatar
Senior Member
ADMINISTRATOR
that is weird both the 2008 Torrent and Equinox use the same front brake calipers, 96626067 and 96626068.
Are those factory or aftermarket wheels from the Equinox?
I would not use washers, you need a 1/4" wheel spacer for a 5-115 bolt pattern.
https://www.summitracing.com/parts/trd-4082/overview/
__________________
  #6
Old May 9th, 2018, 03:37 PM
Junior Member
Looks to be factory..
"..I would not use washers, you need a 1/4" wheel spacer for a 5-115 bolt pattern.
Would those spacers be ok with the studs I have on there now?
  #7
Old May 9th, 2018, 04:57 PM
melsg5's Avatar
Senior Member
ADMINISTRATOR
as long as you buy spacers for a 115-5 bolt pattern they will slide over the studs.
__________________
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2018, vBulletin Solutions Inc.
pontiacforum.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacforum.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
Miss the Pontiac G8 GT? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
