Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac Bonneville Forum
cars connected social network
Pontiac Bonneville Forum Discuss topics regarding the Pontiac Bonneville.
Pontiac Forum: No voltage to the ignition coil '65 Bonneville
Old December 5th, 2017, 07:09 PM
AfterDark3 AfterDark3 is offline
Junior Member
AfterDark3 is on a distinguished road
Well after further inspection, the car must have previously been rewired incorrectly, as the coil gets 8 volts while cranking and 12 at the run state. The wires under the dash are no longer original color codes and the ballast resistor or resistor wire must have been swapped with the one for run. We believe because of this the points are fried, and the condenser may be faulty as well, so we will replace those and see if it gets spark
Old December 6th, 2017, 07:38 PM
Junior Member
An additional question, would it be a good idea to get an inexpensive HEI distributor and simply hooking that up?
Old December 7th, 2017, 10:25 AM
melsg5's Avatar
melsg5 melsg5 is online now
you could do that but it needs 12 volts at all times and make sure you have room for it with respect to the air cleaner assembly
1971 GTO 455 HO Ram Air
2017 Mustang GT
Copyright ©2000 - 2018, vBulletin Solutions Inc. recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 All rights reserved.
