Sign up to remove ads. We'd love to have you amongst our ranks! Just Click here!
pontiac forums   pontiac forums
Go Back   Pontiac Forums > Pontiac CUV and Van Forums > Pontiac Montana Forum
Advertisements
cars connected social network
suspension parts, shocks, struts and more
Notices
Pontiac Montana Forum Discuss topics regarding the Pontiac Montana.
Pontiac Forum: Self accelerate when heated
Reply
Thread Tools
  #11
Old March 8th, 2015, 08:52 AM
thundercat thundercat is offline
Member
thundercat is on a distinguished road
If someone had the same self accelerate problem in a montana and then could repair, I would feel so grateful you share your experience. Thank so much for your attention.
  #12
Old March 8th, 2015, 11:06 AM
Steelcity's Avatar
Steelcity Steelcity is offline
Senior Member
Steelcity is on a distinguished road
I never had an experience like this but you can also check other forums/cars that use the 3400 engine. Have you checked the vacuum lines ?
  #13
Old March 8th, 2015, 01:04 PM
melsg5's Avatar
melsg5 melsg5 is offline
Senior Member
ADMINISTRATOR
melsg5 is on a distinguished road
you have spent a lot of time, money, and effort guessing at replacing parts. How about taking the vehicle to a shop that has a Tech II or similar tool to diagnose how the the throttle positioner, iac, and ecm are interacting with one another to determine the real cause of the problem.
  #14
Old March 10th, 2015, 07:07 PM
Member
  #15
Old March 18th, 2015, 04:57 PM
Member
The needle remains practically without wavering. The test was made with warm engine after 15 minutes. Spraying at several points around manifold, throttle body and several air hoses, needle not change or skip
Click image for larger version
ID:	2301   Click image for larger version
ID:	2302   Click image for larger version
  #16
Old March 19th, 2015, 10:02 AM
melsg5's Avatar
Senior Member
ADMINISTRATOR
Assuming the IAC was replaced with a new one the other possiblity is the ECM but the vehicle should be checked with a Tech II or similar diagnostic tool to confirm this.
  #17
Old March 2nd, 2018, 11:04 PM
Member
Fixed. Changed to a pre-flashed PCM then security relearn sequence
  #18
Old March 3rd, 2018, 05:21 PM
melsg5's Avatar
Senior Member
ADMINISTRATOR
thanks for the update
__________________
1971 GTO 455 HO Ram Air
1969 Corvette Coupe with 1970 LT-1 Short Block
2017 Mustang GT
Reply
Tags
heated, overheating, self accelerate
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2018, vBulletin Solutions Inc.
pontiacforum.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacforum.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
Miss the Pontiac G8 GT? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
