Sign up to remove ads. We'd love to have you amongst our ranks! Just Click here!
pontiac forums   pontiac forums
Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac Grand Am Forum
Advertisements
Pontiac Grand Am Forum Discuss topics regarding the Pontiac Grand Am.
Pontiac Forum: 2004 Grand Am rear wheel cylinder replacement
Reply
Thread Tools
  #1
Old October 6th, 2018, 10:58 AM
HerronScott HerronScott is offline
newb
HerronScott is on a distinguished road
I tried searching for my "issue" here but didn't have any luck so thought I would post in case it helped someone else.
My son's girlfriend's 2004 Grand Am failed inspection due to a leaking rear wheel cylinder and tie rod ends and I'm their go to person for basic car repairs (trying to get my son some experience here but they are in an apartment so more difficult than in a garage with tools, etc).
Tie rod end replacements went well, but I wasn't really looking forward to having to deal with drum brakes again (all our cars have disc brakes all the way around). After I got the brake drum off, the good news was that it looked like I could take the wheel cylinder off without removing any of the rest of the brake assembly just by taking the top spring off and slightly pulling the brake shoes apart on either side of it.
So I pulled the bolt for the brake hose and then started to look at the 2 bolts holding the wheel cylinder to the backing plate and found they are some kind of funky reverse torx head bolt. That's when, I came here searching for size and what tool you would need to get them off and wasn't able to find the answer (maybe my search terms were poor!). I finally found a few references to this needing an E8 wrench (there are E8 sockets as well but I don't think you could get one on them with the vertical link in the way without rotating the backing plate some how). Unfortunately, there weren't any stores locally that carried an E8 wrench that I could get that evening. I also found one reference that said a 1/4" wrench would work and sure enough the closed end of my 1/4" wrench fit perfectly and I was able to get both bolts out. The rest of the replacement went well and I repeated the same on the other side (the brake drum was *very* difficult to get off that side but it finally relented with lots of big hammer pounding on the rear edges alternating sides).
Scott
  #2
Old October 6th, 2018, 03:53 PM
melsg5's Avatar
melsg5 melsg5 is offline
Senior Member
ADMINISTRATOR
melsg5 is on a distinguished road
thanks for the post, I'm sure it will help others.
__________________
1971 GTO 455 HO Ram Air
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2018, vBulletin Solutions Inc.
pontiacforum.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacforum.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
Miss the Pontiac G8 GT? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
