Sign up to remove ads. We'd love to have you amongst our ranks! Just Click here!
pontiac forums   pontiac forums
Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac GTO Forum
Advertisements
Pontiac GTO Forum Discuss topics regarding the Pontiac GTO.
Pontiac Forum: pontiac 1967 400CID manual engine rebuilding
Reply
Thread Tools
  #1
Old June 22nd, 2018, 03:17 PM
Dedek963's Avatar
Dedek963 Dedek963 is offline
Junior Member
Dedek963 is on a distinguished road
I have a Pontiac GTO 1967 4 speed manual.
I bought this car last year in NJ from a guy who serviced the car for 27 years. (I am european, living in Europe so it was a bit difficult for me 😊 )
I have been looking for that car for many years to get it in very original shape. The only not original thing is the engine.
O have been told that this is 1968 GTO 400 engine and it seems to be truth.
Production date seems to be D158
Block casting number 9790071
Engine code 623216 WT
Camshaft 540 / 253 (i have no idea what those numbers are), another numbers 521? / 31 / A /? /D
Crankshaft 9773524 / 107 / N
The diameter of connecting rod journals is 2,241 which means that the crankshaft was at least 2 times repaird (Am I correct?)
There are correct heads 670 (L216)
What is weird is the bore of the cylinders we measured: best value 4,106, worst value 4,118
Also used pistons 9787610 they used to be a part of 421 CID engine
I have no idea how this can happen. A 400 CID block with bore smaller than 4,120. Do you have some explanation for it?
Piston rods: there is no single same number. It seems that there were used piston rods from different engines with the same stroke. The connection rod lenght seems to be 6,625
All the data above seems to allow me to rebuilt the engine to the very original shape.
What I would like to have at the end is an engine better than a factory one with more than 360 HP and 450 Lbs torque. Max safe RPM at about 6500 (BTW: I am using 95 octane fuel)
What I would like to do is:
Change the crankshaft to the right one with a standard (factory new) diameters of journals
Increase the bore to a standard 4,120
Change the pistons and connecting rods to some of better quality than original
If the camshaft is correct, then to keep it. It is mosly untouched. If not then change for the right one
Change the rocker arms (used up) for roller rocker arms
Change valve springs for another with at most 300 lbs (but also not much less)
Of course oil pump and all sealings and gaskets
Might you please help me with yours experience I am lacking to find the right way how to do that and to find the right parts for that purpose?
Many thanks in forward
  #2
Old June 22nd, 2018, 04:02 PM
melsg5's Avatar
melsg5 melsg5 is offline
Senior Member
ADMINISTRATOR
melsg5 is on a distinguished road
If the engine was really a 389, 4.062 bore stock, 4.092 with .30 over pistons and worn out bores.
The 421 pistons are 4.093 so they would roughly fit a .030 bored 389.
With your aim of 6,500 rpm and the collection of parts you have you would best served to contact this company
https://butlerperformance.com/rt-503...ac-engine.html
__________________
1971 GTO 455 HO Ram Air
  #3
Old June 22nd, 2018, 04:15 PM
Dedek963's Avatar
Junior Member
Hi,
You are right... if it was 389 CID engine, the answer would be exactly like this... but the numbers say, it can not be 389 engine...
The only thing what we could imagine was that ... someone could buy an unfinished new 400 CID block and bore it less than 4,120, because he had some 429 pistons...
I have no other explanation...
  #4
Old June 22nd, 2018, 08:14 PM
Dedek963's Avatar
Junior Member
melsg5 thank you for the link. I already contacted them.
  #5
Old June 22nd, 2018, 11:14 PM
melsg5's Avatar
Senior Member
ADMINISTRATOR
an unfinished block wouldnt have WT on it.
Is the number 623216 the last 6 digits of the VIN?
__________________
  #6
Old June 23rd, 2018, 09:07 AM
Dedek963's Avatar
Junior Member
Nope, the last 6 digits does not match with the VIN.
  #7
Old June 23rd, 2018, 11:50 AM
melsg5's Avatar
Senior Member
ADMINISTRATOR
everything points to a 68 400 even the crankshaft number is late 67/early 68 400.
Any chance the measurements you have are not correct?
another shop you can contact is www.wallaceracing.com
good luck and let us know what you end up doing with the car, if you can post pictures that would be great
__________________
  #8
Old June 23rd, 2018, 08:25 PM
Dedek963's Avatar
Junior Member
My first feeling was, the measuring is wrong (despite all other measurings were correct). So I used also another device to be really sure.
Here are the photos of the measurings. please note > one is inches, the other in mm (inch> cm = 1 x 2,54)
  #9
Old June 24th, 2018, 10:49 AM
melsg5's Avatar
Senior Member
ADMINISTRATOR
very puzzling, Butler had no ideas?
have you tried contacting Wallace?
could you post a picture of the back of the car?
__________________
  #10
Old June 24th, 2018, 04:19 PM
Dedek963's Avatar
Junior Member
Yes very puzzling > dismounted to the very last bolt. I want to do it really bottom up and get it into the shape of a new engine.
Some photos above are before cleaning, some after.
Butler has no ideas so far. Maybe because of the weekend.
Wallace will I contact today.
The back of the car corresponds to the date of production > June 1967. Or did you have another reason for seeing it?
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2019, vBulletin Solutions Inc.
pontiacforum.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacforum.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
Miss the Pontiac G8 GT? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
