Sign up to remove ads. We'd love to have you amongst our ranks! Just Click here!
pontiac forums   pontiac forums
Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac GTO Forum
Advertisements
Pontiac GTO Forum Discuss topics regarding the Pontiac GTO.
Pontiac Forum: pontiac 1967 400CID manual engine rebuilding
Reply
Thread Tools
  #21
Old June 27th, 2018, 06:48 AM
Dedek963's Avatar
Dedek963 Dedek963 is offline
Junior Member
Dedek963 is on a distinguished road
Butler promised to make a quote for me today.
  #22
Old June 27th, 2018, 08:58 AM
Dedek963's Avatar
Junior Member
One of the reasons somebody used 421 parts might be the fact that in 1964Car and Driver published a road test of GTO.
That car prepared Jim Wanger Who used some parts from 421.
Although the parts used in the test were not the parts used in my car... It could have been be some "hint" :-)
  #23
Old June 27th, 2018, 09:24 AM
melsg5's Avatar
melsg5 melsg5 is offline
Senior Member
ADMINISTRATOR
melsg5 is on a distinguished road
Do you think the changes were made before the car went to Europe?
__________________
1971 GTO 455 HO Ram Air
  #24
Old June 27th, 2018, 07:08 PM
Dedek963's Avatar
Junior Member
The vehicle history is following:
At least between the years 1990-2017 was the car owned by one owner, who is now at least 60+. In those years nobody opened the engine. Only normal service has been made.
Between 1990-2017 only 3000! miles were driven.
I bought the vehicle in 2017 in USA and brought it to Europe.
2017-2018 another 2300 miles came to the odometer.
The engine is now open after at least 28 years for the first time.
According to the lenght of distribution chain I guess that this modification sits in the engine for more than 40000 miles.
I have no idea when it was made, but my guess would be no later than 1975...
  #25
Old June 28th, 2018, 09:18 AM
melsg5's Avatar
Senior Member
ADMINISTRATOR
Are you aware of the services provided by www.phs-online.com . They have the images of the original window sticker and perhaps other information about the car.
__________________
  #26
Old June 28th, 2018, 07:08 PM
Dedek963's Avatar
Junior Member
Yes, I am.
I have all this documents from Pontiac Historic Services.
BTW still do not have quote from Butlerperformance :-)
  #27
Old July 3rd, 2018, 06:52 PM
Dedek963's Avatar
Junior Member
Hi,
now I have the estimation from Butlerperformance for rotating components, sealings and gaskets and we are working on camshaft and accesories.
  #28
Old July 4th, 2018, 12:40 PM
melsg5's Avatar
Senior Member
ADMINISTRATOR
Ok good luck and keep us posted on how it goes.
__________________
  #29
Old July 24th, 2018, 09:06 PM
Dedek963's Avatar
Junior Member
Hi,
finally I have the quote finished:
here it is:
____________
Balanced Rotating Assembly-3"Mains, 4.250 Str., 6.800 Rod
Pontiac 400 Eagle Cast Crank 3.00" Mains 4.250 Stroke 2.200 Rod Journals
Pontiac 350-389-400 Federal Mogul Race Main Bearings - Pontiac-STD (Set)
ROSS .990 X 2.500" Ross Wrist Pins, 5115 Chromoly, .150"Straight wall/128 gram (Set)
Pontiac ROSS Reverse Dome Pistons-Custom (Set/8)* 4.155, 1.295, 1/16 1/16 1/16 3/16, 72CC HEADS 670, 9.7 CR (this is going to be changed to 10,5 CR)
BBC Eagle CRS 6.800 H Beam 4340 Forged Rods w/ 8740 Bolts 2.200 r.j.-.990 Pins Bushed (Set)
4.155 1/16 1/16 3/16 TS Classic Race Rings - File Fit (Set) (4.150 Oil Ring)
Pontiac RA/SD High Vol. 80 psi Oil Pump-w/o Pick-Up
Pontiac Pro Billet Timing Set
Pontiac Comp Custom Grind Billet Roller Cam (HR) (Std Firing Order/Std Journals) 282/288, 230/236,.510/.521, 114LS
Johnson Lifters, Pontiac Lifter Set, Hi-Perf Hydraulic Roller, 326-455, Set/16
Pontiac 1.5 Ratio Aluminum Roller Rocker Set
1.437 Dual Springs 115 @ 1.700, 340 @ 1.150, Coil Bind 1.050 (Set)
(Of course this are not all parts, just the most important ones)
  #30
Old July 25th, 2018, 09:37 AM
melsg5's Avatar
Senior Member
ADMINISTRATOR
Your gasoline octane will support a 10.5 compression ratio?
Concerning the camshaft that was selected, did they discuss with you the type of transmission, manual or automatic, if automatic the stall speed, and the rear end gear ratio?
Did they give an estimated horse power?
__________________
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2019, vBulletin Solutions Inc.
pontiacforum.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacforum.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
Miss the Pontiac G8 GT? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
