Sign up to remove ads. We'd love to have you amongst our ranks! Just Click here!
pontiac forums   pontiac forums
Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac Grand Am Forum
Advertisements
Pontiac Grand Am Forum Discuss topics regarding the Pontiac Grand Am.
Pontiac Forum: 2001 grand am
Reply
Thread Tools
  #1
Old January 1st, 2018, 02:49 PM
Gilagan Gilagan is offline
newb
Gilagan is on a distinguished road
2001 grand am
i have a 01 grand am and after the car warms up driving say about 30 miles or so it starts to surge and wants to stall. but the weird thing is if i hammer on the brakes it takes
off again for a little bit then it acts up again . would it have anything to do with the ignition
  #2
Old January 1st, 2018, 05:18 PM
melsg5's Avatar
melsg5 melsg5 is offline
Senior Member
ADMINISTRATOR
melsg5 is on a distinguished road
do you have a check engine light on?
how many miles since you changed the fuel filter?
how many miles since you checked the air filter?
__________________
1971 GTO 455 HO Ram Air
  #3
Old March 7th, 2018, 05:06 PM
newb
Air filter is good good fuel pressure.Changed plugs wires etc. My remote car entry module under the glove box has had water in it and shorted out some resisters would that have anything to do with it.
  #4
Old March 7th, 2018, 06:07 PM
melsg5's Avatar
Senior Member
ADMINISTRATOR
have you checked for cracked or broken vacuum hoses?
did you use a fuel pressure gauge to check the pressure?
does the amount of gasoline in the tank effect the problem?
__________________
  #5
Old March 19th, 2018, 08:53 PM
newb
yes i used a fuel pressure guage. this problem started about December when the surging or intermediant misfire was happening. slowly i was loosing power and barely could get 20 mph out of it. so i decided that my cat converter was plugged and cut it off and put a piece of pipe in. doing that i got my power back but still has the misfire. i live 5 kms from work and by the time i get a mile from home it starts acting up. i had it in the shop and they said was try changing my plugs and wires. what would cause my cat conv to plug that much maybe i should be looking at that
  #6
Old March 20th, 2018, 09:31 AM
melsg5's Avatar
Senior Member
ADMINISTRATOR
Again, do you have a check engine light on?
How many miles on the engine?
Have you done a compression test?
what is the fuel pressure reading?
have you tested the coils?
__________________
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2019, vBulletin Solutions Inc.
pontiacforum.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacforum.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
Miss the Pontiac G8 GT? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
