Sign up to remove ads. We'd love to have you amongst our ranks! Just Click here!
pontiac forums   pontiac forums
Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac Grand Am Forum
Advertisements
Pontiac Grand Am Forum Discuss topics regarding the Pontiac Grand Am.
Pontiac Forum: 2002 Grand Am won't start
Reply
Thread Tools
  #1
Old February 11th, 2018, 07:23 PM
wilcom wilcom is offline
Junior Member
wilcom is on a distinguished road
I was getting ready for SMOG and had a code that said the MAF was bad. The car ran ok but would surge a lil bit at idle after awhile. I bit the bullet and bought a new MAF, installed it and now it won't start!! I put the old MAF back in and still won't start. The motor initially starts but then dies after about 1 second. It will do that a couple of times and then NO fire at all.
I have checked all wires in the area that I might have touched and there seems to be nothing amiss. Any ideas ????? I' F'n baffled
PS I went down and got gas just in case it ran out as I changed the MAF... I have had the stars align like that before.....
  #2
Old February 11th, 2018, 10:51 PM
Junior Member
FOUND IT!!! I knew it had to be something simple or stupid that I had done. If I had found it right away it would have been simple. But I scratched my head and worked on it for a day and a 1/2,,,,,,, so now I will have to classify it as (another) stupid thing I have done.
When I put the new MAF sensor on I didn't see the plastic cover INSIDE the sensor when I installed it. Naturally when I went to crank it up the motor sucked the obstruction into the intake track. When I put the old MAF back on to try it the blockage was still there so the outcome was the same, intake blocked, no air, and one of the big three components ya need to make things go boom.
I took the airbox off and looked to see if the filter was in side ways, looked into the front of the MAF, nada , everything looked good. I pulled the MAF off and looked in both sides all was good. I looked into the intake pipe and it looked good too. Not until I stuck my hand in the pipe did I encounter the blockage. You couldn't see the clear plastic blocking the pipe. The first two pictures show what I saw when I looked in the pipe. I had to pierce the plastic with a secrew driver to get it out it was such a nice tight fit.
All's well that ends well they say, but I wish it hadn't been with egg on my face LOL
Click image for larger version
ID:	3524   Click image for larger version
ID:	3525   Click image for larger version
  #3
Old February 12th, 2018, 11:24 AM
melsg5's Avatar
melsg5 melsg5 is offline
Senior Member
ADMINISTRATOR
melsg5 is on a distinguished road
wow that is one big piece of plastic, glad you found it and I assume no more codes.
__________________
1971 GTO 455 HO Ram Air
  #4
Old February 12th, 2018, 11:56 AM
Junior Member
Quote:
Yes it was , the same size as the air duct. It was the protective end cap that came on the new MAF. I didn't see it( very thin and very clear) and the minute I went to crank it, the piece got sucked off the end of the MAF and into the air duct about 1 1/2 inches down the pipe. It was so clear that I looked at it and never saw it, looked right thru it. It wasn't til I tried to put my fingers up the pipe to check for obstructions that I encountered it.
I haven't driven it yet to see if the code comes back. I was cold and late when I found it. hopefully this will be the end of my nightmare.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2019, vBulletin Solutions Inc.
pontiacforum.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacforum.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
Miss the Pontiac G8 GT? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
