Sign up to remove ads. We'd love to have you amongst our ranks! Just Click here!
pontiac forums   pontiac forums
Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac Firebird / Trans Am Forum
Advertisements
cars connected social network
Notices
Pontiac Firebird / Trans Am Forum Discuss topics regarding the Pontiac Firebird and Trans Am.
Pontiac Forum: 301 What trans?
Reply
Thread Tools
  #11
Old November 13th, 2017, 10:20 PM
D Berry D Berry is offline
Junior Member
D Berry is on a distinguished road
Quote:
Originally Posted by D Berry View Post
A 359 Pontiac would be dandy but they're kind of rare aren't they?
Sorry. I meant 350, after it was posted I saw what I had done and tried to edit it and was apparently unsuccessful even in that. The trans may very well be metric, and now I learn the brackets would probably have to be replaced because the 301 has a different deck height. Well I'm starting to think that an engine swap is not in my future unless I pay someone else to do it. A four barrel intake would be nice but do they even exist?
  #12
Old November 14th, 2017, 11:19 AM
melsg5's Avatar
melsg5 melsg5 is offline
Senior Member
ADMINISTRATOR
melsg5 is on a distinguished road
there are no aftermarket intakes for the 301
__________________
1971 GTO 455 HO Ram Air
1969 Corvette Coupe with 1970 LT-1 Short Block
2017 Mustang GT
  #13
Old November 15th, 2017, 04:45 PM
cammerjeff's Avatar
cammerjeff cammerjeff is offline
Senior Member
cammerjeff is on a distinguished road
They did make stock 4bbl intakes for 301's, I had a 79 4bbl 301 powered Firebird Formula. Here is a site that lists a used one for sale
http://www.tacreationsusa.com/intake_manifolds.htm
  #14
Old November 17th, 2017, 12:37 PM
Junior Member
Quote:
I looked on Amazon and they have a number of Edelbrock 71564 Performer RPM intakes listed, new for around $450. Of course they could have been out of production for years now. For twice that amount you could go a self learning FI setup like Holley, if they even make it for a two barrel Rochester intake.
  #15
Old November 17th, 2017, 01:51 PM
melsg5's Avatar
Senior Member
ADMINISTRATOR
the 71564 is a current production manifold and does NOT fit the 301. You need a factory 4bbl for the 301, maybe from a junk yard.
__________________
2017 Mustang GT
  #16
Old November 18th, 2017, 10:19 AM
Junior Member
You are correct, I went back to Amazon and typed in "Pontiac 301 intake manifold" just like before and got the same page. It doesn't even say what size engine it fits which as I look around seems to be the theme with the ads for intakes. Apparently all the engines take the same intake except the 301. Hate to admit it but if there is a engine swap in my future it'll have to be SBC.
  #17
Old November 18th, 2017, 10:33 AM
melsg5's Avatar
Senior Member
ADMINISTRATOR
thats not an ususual swap and is pretty easy other than the transmission bolt pattern being different and requiring an adapter.
__________________
2017 Mustang GT
  #18
Old November 19th, 2017, 01:43 PM
cammerjeff's Avatar
Senior Member
I just don't understand why it has to be a small block Chevy if you do the swap? If you plan on doing a LS or Gen V swap then I understand the thinking. But they will not be unexpensive.
To swap in a SBC you will have to change the Frame plates for the engine mounts, change the trans, or get an adaptor plate, (the adaptor plate is cheaper and easier, but then you have to shorten the driveshaft by the same measurement of the thickness of the adaptor plate. You will still have to swap out all the accessory brackets unless the doner engine comes with all of them you need.
Putting in a Pontiac 350, 400, or 455 would only require the accessory brackets to be swapped if the doner engine does not come with them. They bolt up to your trans, mount with the same motor mounts, and your drive shaft will work unmodified.
A SBC is really not that much cheaper to build than a 400 or 455 Pontiac, and definatly would require less work to install.
I only suggest you look at the cost of the complete conversion before making up your mind. All those little $100 dollar parts add up fast to real money. I know because I have gone down that road in the past.
And if you are looking for a 301 4bbl intake it would have to be a used stock part. The 301 intake only fits that engine and the even smaller Pontiac 265 V8
I did find a Forum dealing with the Pontiac 301 & 265 V8's it may help with your current engine. I am definatly not an expert on the 301's. I know just enough to be dangerous.
http://www.301garage.com/forum/
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2018, vBulletin Solutions Inc.
pontiacforum.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacforum.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
Miss the Pontiac G8 GT? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
