Sign up to remove ads. We'd love to have you amongst our ranks! Just Click here!
pontiac forums   pontiac forums
Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac Firebird / Trans Am Forum
Advertisements
Pontiac Firebird / Trans Am Forum Discuss topics regarding the Pontiac Firebird and Trans Am.
Pontiac Forum: Fix Share, overheating problem
Reply
Thread Tools
  #1
Old November 8th, 2017, 09:47 PM
hazewriter's Avatar
hazewriter hazewriter is offline
Junior Member
hazewriter is on a distinguished road
Pontiac are infamous for heat problems well here is the why it happens. The engineers at Pontiac designed the cooling system that works well as a system, however if something is changed then it doesn’t function correctly anymore. Like, changing the Cam or heads which are changed on my car. What they did is an old hotrodders trick they use an underdrive pulley on the crank. Meaning the crank pulley is equal to or smaller the water pump pulley.
The fix, I fixed this on my car by looking up the part numbers for the pulley of an AC car which are 9790842 and 9790843 for the crank and 9788886 for the water pump. I could not find 9788886 so I used 9796061 with a ˝ inch spacer. 9796061 is for a 4.5-inch water pump and 9788886 is for a 4 inch. The original had an 8” water pump pulley and a 7.25” crank pulley. So, let’s do the math. 1/(8/7.25) x 850 rpm = 770 rpm @ the water pump -VS.- The new pulleys are 6.5” water pump and 8” at the crank. 1/(6.5/8)x 850 rpm = 1046 rpm @ the water pump, a difference of 276 rpm. It no longer overheats at stoplights.
  #2
Old November 9th, 2017, 12:16 AM
melsg5's Avatar
melsg5 melsg5 is online now
Senior Member
ADMINISTRATOR
melsg5 is on a distinguished road
Interesting fix. Are you aware of the spacing of the plates used in the pump?
__________________
1971 GTO 455 HO Ram Air
  #3
Old November 9th, 2017, 08:24 PM
hazewriter's Avatar
Junior Member
yes, that was the first thing corrected. helped but didn't fix the problem.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2018, vBulletin Solutions Inc.
pontiacforum.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacforum.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
Miss the Pontiac G8 GT? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
