Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac Grand Prix Forum
Advertisements
cars connected social network
Notices
Pontiac Grand Prix Forum Discuss topics regarding the Pontiac Grand Prix.
Pontiac Forum: RPM Gauge not working
Reply
  #1
Old June 6th, 2018, 02:40 PM
Nexia86 Nexia86 is offline
Member
Nexia86 is on a distinguished road
Hello from Germany,
the RPM gauge of my 1969 Gran Prix is not working. I crawled under the dashboard and could see that there are only two wires coming out from the gauge: one which is connected with TACH of the HEI distributor and another one which is connected to battery/ignition. I was missing a cable which should be on ground - or am I wrong? Does anybody know if I can remove the gauge without removing the complete dash board?
Thanks a lot for your advise.
Regards
Manuel
  #2
Old June 6th, 2018, 03:36 PM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
To start with HEI did not exist in 1969 so somebody changed something if it is HEI.
You may be able to remove the gauge by dropping any AC ducts under the dash and removing the retaining screws for the gauge.
__________________
1971 GTO 455 HO Ram Air
  #3
Old June 6th, 2018, 03:51 PM
Member
Apart from the fact that it's not the original distributor, shouldn't there be a wire connected to ground? Can I get the RPM pulsation from somewhere else than from the distributor?
  #4
Old June 6th, 2018, 05:17 PM
melsg5's Avatar
ADMINISTRATOR
the rpm signal has to come from the distributor.
did the tachometer work when you purchased the car?
the tachometer has lights with a single wire also, the housing should be grounded.
__________________
  #5
Old June 7th, 2018, 06:46 PM
cammerjeff's Avatar
cammerjeff cammerjeff is offline
cammerjeff is on a distinguished road
Also if the Tach is original to the car it was not rated for the amperage the HEI Dist. puts out. If not modified the HEI will burn out a tach designed for a points ignition system.
If I remember correctly the Dash Tach grounds out to the dash mount itself. Thru a jumper on the back of the tach.
__________________
2009 G8 GT
2006 Mallet LS2 Solstice
1978 Catalina Safari Buick 350 TH350
1978 Sunbird Safari Buick 3.8 2004R
1977 Astre Formula 215 Buick V8 T-5
1973 Lemans Safari 400 4-speed (factory)
1971 Catalina Freeway Enforcer 455 TH400
1969 Firebird Sprint 301 OHC-6 T-5
  #6
Old June 12th, 2018, 08:32 AM
Member
Well, I believe the issue here is that the stock RPM gauge is not capable of the signal the HEI distributor is sending...
How can I make this work??
  #7
Old June 12th, 2018, 11:54 AM
melsg5's Avatar
ADMINISTRATOR
you need to install a tachometer filter similar to this
https://www.corvettemods.com/C3-C4-C...iABEgJfwvD_BwE
__________________
  #8
Old June 13th, 2018, 02:59 AM
Member
Found this one and Waiting to arrive:
https://www.glowshiftdirect.com/hei-...signal-filter/
  #9
Old June 20th, 2018, 02:39 AM
Member
OK so I installed that filtre but it didn´t help. Maybe the gauge was already burned by the high voltage of the HEI...
How can I check that? To remove the gauge I need to uninstall the complete dash I believe?
  #10
Old June 20th, 2018, 09:41 AM
melsg5's Avatar
ADMINISTRATOR
use a voltmeter to determine if you are getting a signal from the Tach terminal of the HEI. If you have to pull the tachometer you drop the lower AC ducts, remove the radio and support bracket, disconnect bulbs and power feed. Loosen the 3 retaining screws rotate the tachometer in a clockwise direction and remove. Those are the instructions from the 1970 factory service manual. Good luck.
__________________
Reply
