Sign up to remove ads. We'd love to have you amongst our ranks! Just Click here!
pontiac forums   pontiac forums
Go Back   Pontiac Forums > Pontiac CUV and Van Forums > Pontiac Trans Sport Forum
Advertisements
Pontiac Trans Sport Forum Discuss topics regarding the Pontiac Trans Sport.
Pontiac Forum: 4T60E transmission leak question : ( for you transmission experts )
Reply
Thread Tools
  #1
Old January 11th, 2016, 06:42 PM
TourNut TourNut is offline
Junior Member
TourNut is on a distinguished road
I have a 4T60E transmission on my 3800 '93 Transport. Rebuilt trans. at 130K . Transmission now (195K miles ) , leaks like a sieve on the left side of van . Redid the pan twice - that wasn't it . Noticed flow coming down left side , looked maybe like it was coming from left output shaft seal so I replaced it . checked splined output shaft in tranny for looseness and found none at all ( like it might deflect seal enough to leak because of worn bearing) . I am now thinking the red transmission fluid leak is coming from something ABOVE the left output shaft . My question is : what is above that area that would leak a stream of fluid , especially when I give engine more gas ? Is there some leak- prone device above there that I can replace without a $2600 transmission job ?
  #2
Old January 11th, 2016, 07:44 PM
EaOutlaw's Avatar
EaOutlaw EaOutlaw is offline
Senior Member
EaOutlaw is on a distinguished road
To find any leak you will need to clean up the transmission case and dry it off.
If you put the vehicle up on Jack stands and just run the engine and inspect for leaks, if none are found, turn off the traction control you should be able to run it up to a reasonable speed and inspect for leaks while someone is holding the throttle at the speed you desire 10-20 MPH should be enough to spot a leak if it is from the axle seal area.
The axle seal you replaced may have worn a grove into the sealing area of the axle.
If you have a reappearing leak at the seal you will have to pull the axle back out and look for a grove where the sealing lip rides on the axle.
If it has worn a grove you may find a repair sleeve or just replace the shaft.
Also some transmissions have a bushing just behind the seal that wears out and will cause a leak. But I am not sure if that applies to your transmission.
The point is do not just guess, clean the transmission case good check the fluid levels and inspect it for leaks. once you know for sure where the leak is coming from we can further advise you what to do.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2018, vBulletin Solutions Inc.
pontiacforum.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacforum.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
Miss the Pontiac G8 GT? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
