Sign up to remove ads. We'd love to have you amongst our ranks! Just Click here!
pontiac forums   pontiac forums
Go Back   Pontiac Forums > Pontiac CUV and Van Forums > Pontiac Trans Sport Forum
Advertisements
Pontiac Trans Sport Forum Discuss topics regarding the Pontiac Trans Sport.
Pontiac Forum: Trans am blower motor and cooling fan won't work
Reply
Thread Tools
  #1
Old November 15th, 2016, 11:54 AM
Trans am guy 23 Trans am guy 23 is offline
newb
Trans am guy 23 is on a distinguished road
Hello I am having a problem with my blower motor not working in my 5L trans am. I replaced the cooling fan switch the cooling fan relay both temperature sensors and the cooling fan motor now I'm having a problem with the power not getting to the cooling fan and the blower motor wont turn on which it did before I changed out the switch for the cooling fan motor. Any help will be greatly appreciated.
  #2
Old November 15th, 2016, 12:44 PM
melsg5's Avatar
melsg5 melsg5 is offline
Senior Member
ADMINISTRATOR
melsg5 is on a distinguished road
I'm a little confused by you interchanging the term blower motor and cooling fan motor. Are you only referring to the motor that is used for cooling of the engine or are you also talking about the HVAC motor?
__________________
1971 GTO 455 HO Ram Air
  #3
Old November 15th, 2016, 02:52 PM
newb
Hey sorry about that let me start over. The cooling fan motor that sits on the radiator has been replaced with it the switch and the relay. Ever since I change the switch the air conditioner and heating motor inside the car hasn't worked. Neither has the new cooling fan motor on the radiator sorry for the confusion haha I was kind of flustered at the time I wrote that
  #4
Old November 15th, 2016, 03:08 PM
melsg5's Avatar
Senior Member
ADMINISTRATOR
You fail to mention what year the car is.
Looking at the 2002 owners manual, are you aware there are 3 fan relays for the cooling system in the engine compartment fuse box?
Did you check the fuse that powers the relays?
Have you checked the fuse for the HVAC blower?
__________________
  #5
Old November 15th, 2016, 03:28 PM
newb
The car is a 1987 trans am 5L with a carb. There is power at the relay and after. There is also power to the switch but no power at the cooling fan motor. Also I changed the fuses for both
  #6
Old November 15th, 2016, 03:51 PM
melsg5's Avatar
Senior Member
ADMINISTRATOR
When you say switch do you mean the temperature sender for the engine cooling fan motor?
__________________
  #7
Old November 15th, 2016, 05:30 PM
newb
Yes I believe it's called the radiator cooling fan switch it goes in the passenger side head underneath the exhaust manifold
  #8
Old November 16th, 2016, 12:35 PM
melsg5's Avatar
Senior Member
ADMINISTRATOR
OK, I'm used to the term temperature sender. How many wires go the sender? If only one check if there is voltage present, if two check if one of them has voltage. If one wire and has voltage, if you ground it the relay should energize, if two and you connect them the relay should energize.
__________________
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2018, vBulletin Solutions Inc.
pontiacforum.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacforum.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
Miss the Pontiac G8 GT? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
