Go Back   Pontiac Forums > Pontiac CUV and Van Forums > Pontiac Montana Forum
Advertisements
cars connected social network
Notices
Pontiac Montana Forum Discuss topics regarding the Pontiac Montana.
Pontiac Forum: Will not power up starter and no shift indicator light
Reply
  #1
Old August 5th, 2017, 07:17 PM
tim1862 tim1862 is offline
Junior Member
tim1862 is on a distinguished road
After replacing lights in the cluster, I now have no power engaging the starter. Engaging the silonoid at the starter Will start the engine but only for three or four seconds then everything shuts down. All fuses are in tact with the exception of in line fuses that I don't have access to. The system acts as if it were in theft mode that still doesn't explain the shift selector lights not working. I'm still thinking maybe a fusible link somewhere has blown but have no idea where to find them.
So to recap; starter is good, the battery is good, fuses are good, it will start when jumped at the solenoid, but then shuts down after a few seconds . The key turns on everything except engaging the starter. I am stumped !!!! For the record this is a 2005 Pontiac Montana base model.
  #2
Old August 7th, 2017, 06:40 PM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
did you replace the lights in the cluster with the battery connected?
do your brake lights work?
__________________
1971 GTO 455 HO Ram Air
2017 Mustang GT
  #3
Old August 19th, 2017, 09:41 AM
Junior Member
I removed the cluster to replace lights, while the cluster was out I back fed the board to ensure diodes(leds) were in correct polarity alignment . This is the one thing I'm concerned about. I will check brake lights , not sure what that connection that has....
  #4
Old August 19th, 2017, 06:56 PM
melsg5's Avatar
ADMINISTRATOR
the starter system requires your foot on the brake pedal to activate the starter
if the brake light switch fails no lights no start
__________________
2017 Mustang GT
  #5
Old August 22nd, 2017, 02:30 AM
Junior Member
Lights work and this van has never needed a foot on the brake to work
  #6
Old August 22nd, 2017, 02:31 AM
Junior Member
It is an issue with the security system
  #7
Old August 22nd, 2017, 10:00 AM
melsg5's Avatar
ADMINISTRATOR
so the security light is displaying a solid light not blinking?
you are correct that the 2005 does not require a foot on the brake.
__________________
2017 Mustang GT
  #8
Old August 23rd, 2017, 01:47 AM
Junior Member
With the key ON, I can jump the power at the starter but after 3-5seconds, the relays click and the engine shuts down.
I had no issues with the vehicle until I worked on the instrument cluster. At which point the gear select indicator lights ceased to function, and when engaging the key the starter will not engage. There is power to the key and power out.
Reply
