Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac Catalina Forum
cars connected social network
Pontiac Catalina Forum Discuss topics regarding the Pontiac Catalina.
Pontiac Forum: 64 Speedometer Fix?
Old March 6th, 2018, 04:49 PM
KBTfilms KBTfilms is offline
Junior Member
KBTfilms is on a distinguished road
64 Speedometer Fix?
Hey everyone.
Wondering if anyone knows how to fix a speedometer on a 64 Catalina? Mine just went out the other day, not sure what to do. All other gauges in the dash work, just the speedometer is not working.
Old March 7th, 2018, 12:21 PM
Kraig1957's Avatar
Kraig1957 Kraig1957 is offline
Junior Member
Kraig1957 is on a distinguished road
It uses a cable that goes from the transmission to the instrument cluster. It is probably broken. The part should be less than $15.
You should be able to get it at an auto parts store.
1964 Pontiac Catalina 389V8+.060, Rotohydromatic 375
1972 Pontiac Lemans 400V8+.020, Turbohydromatic 400
1967 Ford F-100, 352V8, C6 automatic transmission
2003 Ford Crown Victoria, 4.6LV8, automatic transmission
2016 Ford F-350 Dually, 6.7L Turbo Diesel, Automatic transmission
2016 Ford Mustang, 5.0LV8, Automatic transmission
Old March 7th, 2018, 03:25 PM
melsg5's Avatar
melsg5 melsg5 is offline
disconnect the cable from the transmission and attach the inner cable to an electric drill. Spin it slowly and see if the speedometer works.
1971 GTO 455 HO Ram Air
2017 Mustang GT
Old March 11th, 2018, 09:08 PM
cammerjeff's Avatar
cammerjeff cammerjeff is offline
cammerjeff is on a distinguished road
Eliminate the cable 1st as already stated, but it could also have just come loose from either the trans (not likely) or the speedo itself. I have seen the cable come loose from the back of the speedometer a couple of times.
If the cable is still connected and spinning it slowly with a drill does not move the speedo, the cable is the most likely issue. But if changing the cable does not help it is the speedo itself (only seen that 1 time) after that it is either the trans drive gear or driven gear, or both. The driven gear is usually easy to change (but not always, depending on the type of trans you have) the drive gear requires at least the trans tail housing to be removed and may or may not be somewhat easy to change, again subject to the trans type you have. It also get somewhat complicated to determine what ratio drive or driven gears you need.
Lets hope it is either a loose or Bad cable as that is the cheapest & easiest fix.
Please let us know what you find.
2009 G8 GT
2006 Mallet LS2 Solstice
1978 Catalina Safari Buick 350 TH350
1978 Sunbird Safari Buick 3.8 2004R
1977 Astre Formula 215 Buick V8 T-5
1973 Lemans Safari 400 4-speed (factory)
1971 Catalina Freeway Enforcer 455 TH400
1969 Firebird Sprint 301 OHC-6 T-5
Copyright ©2000 - 2018, vBulletin Solutions Inc. recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 All rights reserved.
