Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac Sunbird Forum
Advertisements
cars connected social network
Notices
Pontiac Sunbird Forum Discuss topics regarding the Pontiac Sunbird.
Pontiac Forum: 91 Pont Sunbird 2.0L Le injector sprays then stops
Reply
  #1
Old November 2nd, 2018, 01:34 PM
onlyeverastein onlyeverastein is offline
newb
onlyeverastein is on a distinguished road
I start the car, the injector sprays fuel and then it just stops spraying fuel. I replaced fuel pump, fuel lines, fuel filter, injector, ECM, fuel pressure regulator, throttle position sensor, pulled and cleaned throttle body and it stills does the same thing. When checking injector pulse the pulse never goes away. The injector just stops spraying. Any info appreciated?
  #2
Old November 2nd, 2018, 05:19 PM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
you have checked for spark?
all though not specific to your vehicle there are diagnostics in this link you could follow
http://www.73-87chevytrucks.com/tech...TBISystems.pdf
__________________
1971 GTO 455 HO Ram Air
  #3
Old November 2nd, 2018, 06:06 PM
92 Sunbird LE's Avatar
92 Sunbird LE 92 Sunbird LE is offline
92 Sunbird LE is on a distinguished road
Sounds to me like a electrical problem.The 91's have a problem where the wires to the fuel pump run off the fuse box and get corroded.
Also check the bulk connector to the engine compartment.Mine was loose and it took me 2 weeks to figure it out. I wiggled the wires to it and the car would start and then have the no start condition. One bolt connects it through the firewall to the fuse box.
Did you swap relays ( passenger side under the hood - 3 relays ) to see if that was it also?
Also check you computer engine grounds. ( 3 or more wires bolted to the clyinder head)
Doug in P.R.
Reply
Tags
injector
