Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac Bonneville Forum
Advertisements
cars connected social network
Notices
Pontiac Bonneville Forum Discuss topics regarding the Pontiac Bonneville.
Pontiac Forum: 1967 Bonneville Carb Options, HELP
Reply
  #1
Old February 6th, 2018, 07:46 PM
72k20subn's Avatar
72k20subn 72k20subn is offline
Junior Member
72k20subn is on a distinguished road
Hello,
I'm a new member to this forum, as I've recently became an owner of a 1967 Bonneville. I'm more familiar with earlier models, 62-64, so the 67 is new territory. I'm very excited to start building knowledge about this vehicle, and start tinkering.
The 67 I recently purchased is a surprisingly clean car, but as in most cases there have been a few mod's through its life, which I would like to reverse. It's got an edelbrock intake, a holley carb, and crummy chrome valve covers and air cleaner. I'd like to pull the engine, clean it up, and bring it back to stock up top if possible.
My questions are in regards to the intake, carb, and air cleaner option that would have been stock on this car. I understand Pontiac went though a transition from 389 to 400, along with a variety of carbs as this transition occurred between early 67 and late 67. I'd like to understand the stock type and numbers that would have been on my car, any ideas? The build sheet indicates the car built with L78 400 4bbl, XX engine code, 4505 air cleaner code, and PA carb code, TH400, A/C, california car. Anyone know if the carb should be Carter or a Rochester? It is my understanding that SOME early 67 fullsize may have been equipped with Carters? Need correct intake and numbers if possible.
Much thanks to anyone who can help me identify the correct equipment (and numbers too look for) so that I can begin hunting these items down, and put the car back to the way it was.
  #2
Old February 7th, 2018, 11:38 AM
melsg5's Avatar
melsg5 melsg5 is online now
ADMINISTRATOR
Did you order the vehicle information packet from www.phs-online.com which would tell you in more detail what the car came with and when it was manufactured . I thought the Quadrajet was the only carb for 67 but this link also shows the Carter based on what size engine and horsepower. http://www.pontiacpower.net/numbers/...anifold-codes/
The factory issue of the Service Manual for 1967 section 6B has carburetor numbers.
Why do you list the engine code as XX, you dont see the code?
__________________
1971 GTO 455 HO Ram Air
2017 Mustang GT
  #3
Old February 7th, 2018, 02:58 PM
melsg5's Avatar
ADMINISTRATOR
i did some more research and the engine code should tell you the type of carburetor, the 70272xx are Quadrajets and the 4242S is a Carter
293 HP XC 4242S Block Casting # 9786133
325 HP XN 7027276 RA Block Casting # 9786133
325 HP XW 4242S Block Casting # 9786133
325 HP XX 4242S A/C Block Casting # 9786133
325 HP YE 4242S Block Casting # 9786133
__________________
2017 Mustang GT
  #4
Old February 7th, 2018, 06:13 PM
72k20subn's Avatar
Junior Member
melsg5, This is awesome info. Much thanks! Exactly the starting point I was looking for.
I'll also take your advice on ordering PHS docs to confirm, but it looks as if this helps point me in the right direction based off the XX engine code. I'll turn next to the block casting #'s to see if it also matches up.
  #5
Old February 7th, 2018, 08:24 PM
melsg5's Avatar
ADMINISTRATOR
I see it is XX so the correct carburetor is the Carter 4242s and the intake is 9782896
__________________
2017 Mustang GT
  #6
Old February 7th, 2018, 11:52 PM
72k20subn's Avatar
Junior Member
Awesome. A huge help having those intake and carter carb part numbers.
Looking at the oringal air cleaner in the trunk of the car, its part# is 6424505, mirroring the build sheet code "4505". I see the housings carb opening is smaller than that of a 4bbl-Rochester, and bigger than that of a 2bbl setup.
All this is aligning & supporting its factory setup as a carter 4bbl.
Greatly Appreciated!
  #7
Old February 7th, 2018, 11:54 PM
72k20subn's Avatar
Junior Member
.... and now the fun part.
Hunting these down at a reasonable price. =-)
  #8
Old February 8th, 2018, 10:08 AM
melsg5's Avatar
ADMINISTRATOR
you have left the world of reasonable prices, you have entered the ................
__________________
2017 Mustang GT
  #9
Old February 9th, 2018, 10:19 AM
72k20subn's Avatar
Junior Member
LOL .... true.
  #10
Old April 1st, 2018, 03:27 PM
67Exec 67Exec is offline
newb
67Exec is on a distinguished road
I have a mechanical choke version of the correct carb that came a set of heads and factory square bore intake(can't remember number off hand) that I picked up about 8yrs ago to switch my 67 Executive from a 2jet to a holley. I rebuilt the Carter and ran it for a couple yrs, then ended up running a very early torquer intake and a 650 holley. This setup yields plenty of low end and on a 4hr road trip yielded 26mpg
Reply
