Go Back   Pontiac Forums > Pontiac CUV and Van Forums > Pontiac Aztek Forum
Advertisements
Pontiac Aztek Forum Discuss topics regarding the Pontiac Aztek.
Pontiac Forum: Starting issue
Reply
  #1
Old December 6th, 2018, 11:21 AM
grantkat grantkat is offline
Junior Member
grantkat is on a distinguished road
Starting issue
I am working our 2001 aztek. We had the typical key issue and I used the manual release to unlock and get the key out. However, I am getting the folling symptoms:
When I put the key in and turn it everything is blank and I get zero response. Battery is good and has full charge. However I noticed when turning the key some of the dash lights come on for a moment then off. If i turn the key back and forth there seems to be a spot where the lights work while turning the key, however when you get to the start and run positions there is nothing. Seems like a back ignition swtich? is there anything on the process for removing and replacing the switch?
I was hoping to get to the switch, check wires etc and make sure everything is connected and clean, then if necessary replace the swtich.
I cannot find anything on the removal/replacement of ignition swtich.
Any suggestions and help would be appreciated.
  #2
Old December 6th, 2018, 12:25 PM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
this is for the Buick Rendezvous which is the same as the Aztek
https://www.youtube.com/watch?v=nLHwyMleBGU
__________________
1971 GTO 455 HO Ram Air
Reply
