Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac GTO Forum
Advertisements
Pontiac GTO Forum Discuss topics regarding the Pontiac GTO.
Pontiac Forum: Gears for the rear end carrier
Reply
  #1
Old December 11th, 2018, 10:35 AM
dwd70gto dwd70gto is offline
Junior Member
dwd70gto is on a distinguished road
I have a XH rear carrier with 355 gears in it. Will this carrier accept a 336 gear or do I need to get a different carrier.
  #2
Old December 11th, 2018, 11:18 AM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
all three series carriers will accept any 3.xx gear. Why are you going from a 3.55 to a 3.36 doesnt seem to be worth the effort. I went from a 3.08 to a 3.55 and that was a very noticeable difference.
__________________
1971 GTO 455 HO Ram Air
  #3
Old December 11th, 2018, 03:15 PM
Junior Member
I drive my car about 200 miles on the express way to visit my mom and my kids.
I would like something that will not tack the engine so hi when going 70.
  #4
Old December 11th, 2018, 06:31 PM
melsg5's Avatar
ADMINISTRATOR
I did a little more research and found out they did have a difference in three series carriers, the dividing line being the 3.36. So the lowest you can go is the 3.36. The next lowest 3.23 started using a different carrier.
http://www.iegtoclub.com/Tech%20Lib/...tification.htm
__________________
  #5
Old December 12th, 2018, 09:32 AM
Junior Member
Thanks. I think the lowest i want is to go is the 336. So I should be good with the carrier I have.
  #6
Old December 14th, 2018, 03:09 PM
Junior Member
Does anyone have the formula for calculating the engine rpm base on the rear gear ratio and the tire o.d.
  #7
Old December 14th, 2018, 06:27 PM
melsg5's Avatar
ADMINISTRATOR
here you go, So if you have a 27" tire and currently have the 3.55 at 70 mph the engine turns at 3,092 rpm. Going to a 3.36 produces 2,927 rpm. Thus my original thought it is not worth the effort for such a small difference.
https://www.crawlpedia.com/rpm_gear_calculator.htm
__________________
  #8
Old December 14th, 2018, 10:40 PM
Junior Member
Thanks for the info. I see that changing from my 235/60r/14 to a 255/60r/15
might help my problem
  #9
Old December 14th, 2018, 10:51 PM
Junior Member
Also since I changed my mufflers the rpm range isn't as big of problem any more. The road noise inside the car at 70 mph has decreased big time.
  #10
Old December 15th, 2018, 11:50 AM
melsg5's Avatar
ADMINISTRATOR
If you are going to change from 14" to 15", I would consider going to 17". The selection of modern tire designs are not found in 15" tires.
__________________
Reply
