Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac Sunfire Forum
Advertisements
Pontiac Sunfire Forum Discuss topics regarding the Pontiac Sunfire.
Pontiac Forum: 1999 Sunfire Fuel Pump Inertia Switch?
Reply
  #1
Old January 5th, 2019, 12:44 PM
JasamHen JasamHen is offline
Junior Member
JasamHen is on a distinguished road
My car will run fine for weeks and then suddenly will just not start. I've discovered this is because the fuel pump isn't turning on, and have been working on whatever is causing that. Sometimes I can jiggle some wires under the dash and it will then prime, sometimes I pull out a connection and plug it back in and it will prime, other times I don't do anything and it will just magically start working again.
I've always assumed that if it was my fuel pump, it wouldn't be intermittent, it would just die and that would be the end of it. But because I can get it going again, I feel like it is an electrical issue of some sort.
Autozone sells a fuel pump inertia switch for my vehicle, but I have no idea where it is located. Does anyone else have any ideas where it might be?
Or any other suggestions as to why my car will randomly just not start? Thanks for reading.
  #2
Old January 5th, 2019, 07:32 PM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
fuel pump relay, fuel pump, ignition switch
I do not see the switch you refer to in the wiring diagram
https://www.autozone.com/repairinfo/...00c1528003cfdd
__________________
1971 GTO 455 HO Ram Air
  #3
Old January 6th, 2019, 09:35 AM
92 Sunbird LE's Avatar
92 Sunbird LE 92 Sunbird LE is online now
92 Sunbird LE is on a distinguished road
Check where the wires under the hood connect to the firewall bulkhead connector( which then run to the fuse box inside ) had a similar problem on my Sunbird.( Wouldn't start without shaking wires)
Swap out the fuel pump relay ( with similar one in the fuse box under the hood), and check the ignition switch also for burnt wires.
Doug in P.R.
Reply
