Sign up to remove ads. We'd love to have you amongst our ranks! Just Click here!
pontiac forums   pontiac forums
Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac LeMans Forum
Advertisements
cars connected social network
Notices
Pontiac LeMans Forum Discuss topics regarding the Pontiac LeMans.
Pontiac Forum: Ignition power
Reply
Thread Tools
  #1
Old February 25th, 2018, 03:28 PM
spectrumad spectrumad is offline
Member
spectrumad is on a distinguished road
Ignition power
OK, next question. 1971 Pontiac Lemans 350. HEI conversion. I have power at the distributor when the key is on. No power when the key is off. I lose power, 0 volts, when the key is moved to the crank position. I have check fuses and have not found anything blown. This car ran with this wiring a couple weeks ago. I ran a temp power directly to the battery to confirm it starts that way. Any guesses?
  #2
Old February 25th, 2018, 06:04 PM
melsg5's Avatar
melsg5 melsg5 is offline
Senior Member
ADMINISTRATOR
melsg5 is on a distinguished road
who installed the HEI and what modifications to the wiring were done?
the double wire that was used with the points ignition system and connected to the + positive terminal of the stock coil had one wire coming from the starter and one wire coming from the ignition switch. When cranking the coil received full battery voltage through the ignition switch. When running the coil received reduced voltage through the resister wire coming from the starter. A HEI reguires full voltage all the time so trace the wire from the BAT terminal on the HEI to find out where it goes.
__________________
1971 GTO 455 HO Ram Air
  #3
Old February 25th, 2018, 06:11 PM
Member
I installed the HEI. It has a full 12V, no resistor involved from the original coil.
  #4
Old February 26th, 2018, 11:01 AM
melsg5's Avatar
Senior Member
ADMINISTRATOR
you did understand that the stock wiring on a 1971 does NOT supply a full 12 volts while running, it uses the stock resistor wire coming from the starter to supply about 9 volts. So what did you do specifically to the dual wire that connected to the positive terminal of the stock 1971 coil in order to connect it to the BAT terminal of the HEI distributor? If your answer is you did nothing other than splice the dual wire to the BAT terminal then your problem is the wire from the starter broke and it should not have been used to start with.
__________________
  #5
Old February 27th, 2018, 04:00 PM
Member
Sorry I was not specific. I had run a new power feed to the fuse panel. I bypassed the stock wiring originally, knowing the resistor would cause issue. I found a blown fuse (did not look blown but was) and all is well with the world again.
  #6
Old February 27th, 2018, 05:35 PM
melsg5's Avatar
Senior Member
ADMINISTRATOR
OK, that makes sense, glad you found it.
__________________
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2018, vBulletin Solutions Inc.
pontiacforum.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacforum.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
Miss the Pontiac G8 GT? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
