Sign up to remove ads. We'd love to have you amongst our ranks! Just Click here!
pontiac forums   pontiac forums
Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac LeMans Forum
Advertisements
cars connected social network
Notices
Pontiac LeMans Forum Discuss topics regarding the Pontiac LeMans.
Pontiac Forum: Hei ported or manifold vacuum
Reply
Thread Tools
  #1
Old April 22nd, 2018, 09:57 PM
Lemansddj Lemansddj is offline
Junior Member
Lemansddj is on a distinguished road
Ok I got a 1970 Pontiac 350 with a summit 600 cfm carb and was wondering if the vacuum advance should go on ported or manifold ports
I heard that manifold vacuum could help keep the temps down while in traffic
  #2
Old April 23rd, 2018, 09:23 AM
melsg5's Avatar
melsg5 melsg5 is offline
Senior Member
ADMINISTRATOR
melsg5 is on a distinguished road
You are correct running the line to a constant vacuum source is preferable to a ported source. The ported source came about due to emissions restrictions. Prior to that there was no ported source.
__________________
1971 GTO 455 HO Ram Air
1969 Corvette Coupe with 1970 LT-1 Short Block
2017 Mustang GT
  #3
Old April 23rd, 2018, 09:36 AM
cammerjeff's Avatar
cammerjeff cammerjeff is offline
Senior Member
cammerjeff is on a distinguished road
While I agree with melsg5 that manifold vacuum is usually best for vacuum advance, I have seen some individual cars that ran better with ported vacuum source. I think it has a lot to do with the specific cam shaft, and how worn all the componates are.
But I always start out with direct manifold vacuum on the Dist.
__________________
2009 G8 GT
2006 Mallet LS2 Solstice
1978 Catalina Safari Buick 350 TH350
1978 Sunbird Safari Buick 3.8 2004R
1977 Astre Formula 215 Buick V8 T-5
1973 Lemans Safari 400 4-speed (factory)
1971 Catalina Freeway Enforcer 455 TH400
1969 Firebird Sprint 301 OHC-6 T-5
  #4
Old April 23rd, 2018, 03:19 PM
Junior Member
thanks
I have it on manifold now and will adjust the curb idle speed and the air/fuel mixture screws
maybe this will help with the off green light bog
  #5
Old April 26th, 2018, 07:14 PM
avell007's Avatar
avell007 avell007 is offline
Member
avell007 is on a distinguished road
Check your carb accelerator pump for that off idle bog , if you think it's timing you could put lighter springs on the centrifugal advance so it advances quicker off idle .
__________________
1970 Catalina Convertible
1969 RS Camaro Forced Induction
1981 Corvette
  #6
Old April 27th, 2018, 11:50 AM
melsg5's Avatar
Senior Member
ADMINISTRATOR
how did you mount a Summit 600 cfm carburetor on a Pontiac manifold, factory Pontiac is spread bore the carburetor is square bore. Which intake manifold are you using?
__________________
2017 Mustang GT
  #7
Old May 1st, 2018, 01:43 PM
Junior Member
Sorry I did not it is on a Edelbrock performer intake
  #8
Old May 1st, 2018, 02:38 PM
melsg5's Avatar
Senior Member
ADMINISTRATOR
the carburetor looks a lot like a Holley. With the engine off disconnect the throttle return spring. Hold the throttle wide open and at the same time press down on the primary accelerator pump arm. You should be able to insert a .015 feeler gauge between the arm and the adjustment screw on the throttle linkage which presses down on the arm. The video below explains the adjustment.
https://www.youtube.com/watch?v=k-Nx5HEzvlY
__________________
2017 Mustang GT
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2018, vBulletin Solutions Inc.
pontiacforum.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacforum.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
Miss the Pontiac G8 GT? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
