Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac GTO Forum
Advertisements
cars connected social network
Notices
Pontiac GTO Forum Discuss topics regarding the Pontiac GTO.
Pontiac Forum: 65 GTO Hurst Trans Question
Reply
  #1
Old May 18th, 2018, 10:18 AM
Tomdex Tomdex is offline
newb
Tomdex is on a distinguished road
I have a 65 GTO with a Hurst 4 spd transmission.
When cold it sticks in reverse as I back out of the garage. It will go into 1st gear but as I release the clutch, it sticks in reverse. I slowly release the clutch in first gear, it remains in reverse and feels like its going to die and it is reverse.
I run thru the gears, then slowly release the clutch and eventually it either clunks into 1st or it clears the issue and I can operate it as normal.
This only happens when the car is cold, never after being driven.
Trans issue or throw out bearing issue or ???
  #2
Old May 18th, 2018, 12:24 PM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
what you have is a hurst shifter on a munice transmission. Place the car on a lift or jack stands and using an engine degreaser product clean the shifter and linkage. After washing off the grime lightly lubricate the mechanism. At the same time with the shifter in neutral take a box end wrench and make sure the 3 shift mechanism shaft bolts or nuts are tight. One is for the 1-2 gears, the other is for the 3-4 gears and the last is for reverse.
__________________
1971 GTO 455 HO Ram Air
Reply
