Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac Sunbird Forum
Advertisements
Pontiac Sunbird Forum Discuss topics regarding the Pontiac Sunbird.
Pontiac Forum: Gauges work intermittently
Reply
  #1
Old November 18th, 2018, 11:03 AM
Phil Number 3 Phil Number 3 is offline
newb
Phil Number 3 is on a distinguished road
My speedometer, engine temp gauge, oil pressure and alt light quit one day. I searched and found a relay that I thought was the problem. I exchanged it and everything worked ... for a while.
Later I discovered that when cold, everything works but when the cabin is warm, especially the foot are, the gauges quit then when cold, start working again.
Anyone have a clue ? I've checked connections and fuses and everything looks fine so I am at a loss. I did find a small box behind the dash with a wheel adjustment but I have NO idea what it is or does.
  #2
Old November 18th, 2018, 07:40 PM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
could be a bad circuit board in the cluster.
__________________
1971 GTO 455 HO Ram Air
  #3
Old November 19th, 2018, 08:12 PM
newb
I'm afraid you might be right.
  #4
Old November 20th, 2018, 01:44 PM
cammerjeff's Avatar
cammerjeff cammerjeff is offline
cammerjeff is on a distinguished road
I would check the grounds 1st, a bad ground can cause all kinds of strange issues.
But it could also be the board, or a loose connection.
__________________
2009 G8 GT
2006 Mallet LS2 Solstice
1978 Catalina Safari Buick 350 TH350
1978 Sunbird Safari Buick 3.8 2004R
1977 Astre Formula 215 Buick V8 T-5
1973 Lemans Safari 400 4-speed (factory)
1971 Catalina Freeway Enforcer 455 TH400
1969 Firebird Sprint 301 OHC-6 T-5
  #5
Old November 22nd, 2018, 02:20 PM
92 Sunbird LE's Avatar
92 Sunbird LE 92 Sunbird LE is offline
92 Sunbird LE is on a distinguished road
The instrument cluster snaps into a electrical port with all the metal fingers exposed, they can get coroaded after time and make no good connection. The cluster will have to come out to check this, have fun with all the screws and plastic trim you have to remove to take it out....
Doug in P.R.
  #6
Old November 22nd, 2018, 02:25 PM
The instrument cluster snaps into a electrical port with all the metal fingers exposed, they can get coroaded after time and make no good connection. The cluster will have to come out to check this, have fun with all the screws and plastic trim you have to move to take it out....
Doug in P.R.
  #7
Old November 24th, 2018, 11:23 AM
pippo pippo is offline
Member
pippo is on a distinguished road
Quote:
Doug in P.R.
Right, Doug, but I have done this many times and it is not so difficult. tedious a bit, but overall easy. I had to replace tiny plastic sprocket wheels which were broken , driving the odometer.
Anyway, easy project.
  #8
Old November 26th, 2018, 09:14 AM
newb
Thanks for the updates. I'm in the middle of removing it all. Finding all of the screws seems to be the challenge
Reply
