Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac GTO Forum
Advertisements
cars connected social network cars connected social networking app for ios cars connected social networking app for android
Notices
Pontiac GTO Forum Discuss topics regarding the Pontiac GTO.
Pontiac Forum: Left turn signal rear light does not work on '67 GTO
Reply
  #1
Old November 6th, 2017, 11:13 PM
redgoat1967 redgoat1967 is offline
Junior Member
redgoat1967 is on a distinguished road
The left turn signal light does not blink when lever is activated. It will only blink when steering column lever is held half way in the "lane changing position." Also, if I have my foot on the brake, the brake lights will illuminate on both sides but the left brake light will go out all together if I move the turn signal lever to the full left turn position. Right brake light continues to illuminate. Brake lights work properly if no left turn is activated. Right rear tail lights work perfectly at all times. Parking lights work OK on both sides. Hazard lights work OK. Front turn signal/parking lights work OK. Dash lights for turns work OK. This steering wheel is plastic, non-wood, and non tilt. I'm thinking that something is not making contact when I signal for a left turn. Rather than just replace my switch assembly, I would like to know if something else is causing my problem. It's interesting that the left turn signal will blink only when turn signal lever is in the "lane changing mode" and not work at all when lever is fully engaged. Any suggestions on what might be causing this issue?
  #2
Old November 7th, 2017, 10:54 AM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
everything you are saying leads to a bad contact in the switch. Pull the steering wheel and examine the switch contact.
__________________
1971 GTO 455 HO Ram Air
2017 Mustang GT
  #3
Old November 7th, 2017, 09:52 PM
Junior Member
I pulled the wheel but I guess I will need a special "J" tool remove the switch. When you say possible bad contact in the switch do you mean some visable surface areas may need to be cleaned? Also, where does the end harness connect to? Someone suggested that I clean the contact pins and reinsert. Any thoughts?
  #4
Old November 8th, 2017, 09:00 PM
Junior Member
Are you referring to a contact that is visable and perhaps needs cleaning or a contact that is internal within the switch?
  #5
Old November 9th, 2017, 12:15 AM
melsg5's Avatar
ADMINISTRATOR
when you move the switch handle can you see what contacts engage or perhaps the switch has to be removed
__________________
2017 Mustang GT
Reply
Copyright ©2000 - 2017, vBulletin Solutions Inc.
