Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac Grand Am Forum
Advertisements
cars connected social network
Notices
Pontiac Grand Am Forum Discuss topics regarding the Pontiac Grand Am.
Pontiac Forum: Power Steering Issue
Reply
  #1
Old April 12th, 2018, 09:21 PM
rickpo rickpo is offline
Junior Member
rickpo is on a distinguished road
Hi all. Been a while since ive visited here. I'll get to it.
2000 Grand Am 4cyl engine. Replaced power steering pump 2x. Original one started leaking.
First replacement, the reservoir leaked, got another.
Current one has no leaks.
Problem is that daughter tells me that as the car warms up, the steering will suddenly get real tight. I have bled it more than once. Fluid will go up and down as I turn the wheels. Not sure if there is some sort of bleed screw or something.
Wanted to add, the p.s on this car is not belt driven, it's driven by the cams.
Any ideas? Thanks in advance
  #2
Old April 13th, 2018, 09:37 AM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
So it sounds like you have a 2.4 engine. Can you do a pressure test? Since the problem happens only when warm could be the pump or the steering rack.
__________________
1971 GTO 455 HO Ram Air
2017 Mustang GT
  #3
Old April 13th, 2018, 12:01 PM
Junior Member
Would the tools needed be able to be rented? Any idea how much pressure, hiw long to hold etc?
Yes it has the 2.4.
  #4
Old April 13th, 2018, 01:07 PM
melsg5's Avatar
ADMINISTRATOR
you should be able to rent the gauge. I cannt find a number, try a Hanes or Chilton manual, some libraries carry them. There is no hold number, you test with a running engine.
__________________
2017 Mustang GT
  #5
Old April 15th, 2018, 02:08 PM
Junior Member
Well just got the pump off. Its lts not a hard job just havent had time. The pin that goes into the cam drive has sheared off. Why does this happen?
PLEASE HELP!!!
Im on my way to get another.
  #6
Old April 15th, 2018, 04:26 PM
melsg5's Avatar
ADMINISTRATOR
i would assume to prevent damage to the cams if the pump seizes
__________________
2017 Mustang GT
  #7
Old April 17th, 2018, 01:39 AM
Junior Member
Good point. I guess it seized up. Got a new one put in. It was under warranty so didn't cost me a thing. Problem is that this is the 3rd one I get from Oreillys. I read NOT to go with a re-manufactured one, but like always... cost is an issue.
So far so good. We'll see how this one works.
Reply
