Go Back   Pontiac Forums > Pontiac CUV and Van Forums > Pontiac Montana Forum
Advertisements
cars connected social network
Notices
Pontiac Montana Forum Discuss topics regarding the Pontiac Montana.
Pontiac Forum: I have a power window problem
Reply
  #1
Old April 15th, 2018, 11:56 PM
Jseagle Jseagle is offline
newb
Jseagle is on a distinguished road
My passenger side window will not go down. The motor is not bad, and the switch isn't bad. I took off the door panel and hooked up a new motor. Also hooked up a new switch on the passenger side. With both the old and new motor, still got nothing, but with the switch on the driver's side, the switch would operate both motors( new and old in the up position. So I have no way to roll down the window. Any ideas?
  #2
Old April 16th, 2018, 11:28 AM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
are you working with a voltmeter or test light and an ohmmeter to determine if you have power and ground?
did you check for a broken wire in the rubber conduit between the door and the frame?
__________________
1971 GTO 455 HO Ram Air
2017 Mustang GT
  #3
Old April 16th, 2018, 11:26 PM
newb
I was not using a test meter. I will check for a broken wire, but I was wondering if there is a relay? Also, I don't understand why the driver's side switch will engage the motor if I pull the switch like I am trying to raise the window on the passenger side, but niether switch will engage it trying to put the window down.
  #4
Old April 17th, 2018, 09:18 AM
melsg5's Avatar
ADMINISTRATOR
There is a relay but it has nothing to do with your problem since the motor does function in one direction and the others have no problem. Here is a wiring diagram.
http://sylkcream.com/the-super-aweso...esi-that-good/
__________________
2017 Mustang GT
Reply
