Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac LeMans Forum
Advertisements
Pontiac LeMans Forum Discuss topics regarding the Pontiac LeMans.
Pontiac Forum: Carburetor Flooding When Hot
Reply
  #1
Old August 5th, 2018, 07:04 PM
Maxxthedog Maxxthedog is offline
Junior Member
Maxxthedog is on a distinguished road
Hi Gang,
I have search this (and other) sites and seen similar issues to mine but not quite the same.
1972, 350 2bbl, 350 auto, all stock.
New, manual stock fuel pump.
Carb was rebuild.
After driving car and it is how (about 30 minutes or so), the engine will flood and die. I was finally able to get it to do this in the garage with the air cleaner off. I looked down the carb and gas as pouring into the carb. It only does this when hot.
I have seen this issue on a hot restart, but never while driving down the road.
I have seen a recommendation to check my fuel pressure. How do I do that? Just put a hose on the end of the fuel line that does to the carb and crank the engine?
For those of you that have a psi gauge in-line, how did you do it? I have one solid metal line that runs from the fuel pump to the carb.
Thanks
  #2
Old August 6th, 2018, 10:49 AM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
you probably will want to rent a tester and connect it to the end of the line.
You either have too much pressure or the float was not correctly adjusted or installed.
Do you know the published PSI of the pump that you installed?
__________________
1971 GTO 455 HO Ram Air
  #3
Old August 7th, 2018, 02:10 PM
cammerjeff's Avatar
cammerjeff cammerjeff is offline
cammerjeff is on a distinguished road
My guess would be the float level set to high.
__________________
2009 G8 GT
2006 Mallet LS2 Solstice
1978 Catalina Safari Buick 350 TH350
1978 Sunbird Safari Buick 3.8 2004R
1977 Astre Formula 215 Buick V8 T-5
1973 Lemans Safari 400 4-speed (factory)
1971 Catalina Freeway Enforcer 455 TH400
1969 Firebird Sprint 301 OHC-6 T-5
  #4
Old August 12th, 2018, 02:54 AM
Kraig1957's Avatar
Kraig1957 Kraig1957 is offline
Member
Kraig1957 is on a distinguished road
If the pressure is too high, you could get an adjustable in-line fuel pressure regulator. I have used a type similar to the Mr. Gasket 9710.
I set it at 3.5 psi with an electric fuel pump and that was enough for my 1972 Lemans with a 400 cubic inch V8 and an Edelbrock 625cfm carb. I have also used it with an Edelbrock Quadrajet Carb, back when I had to still get the car smog checked in California.
__________________
1964 Pontiac Catalina 389V8+.060, Rotohydromatic 375
1972 Pontiac Lemans 400V8+.020, Turbohydromatic 400
1967 Ford F-100, 352V8, C6 automatic transmission
2003 Ford Crown Victoria, 4.6LV8, automatic transmission
2016 Ford F-350 Dually, 6.7L Turbo Diesel, Automatic transmission
2016 Ford Mustang, 5.0LV8, Automatic transmission
  #5
Old September 17th, 2018, 08:50 PM
Junior Member
UPDATE Finally
Thanks for all of the help.
Looks like the float was set wrong. I set it to the instructions and it still acted up. Lowered it a bit and was better. When it is real hot it will still act up so I might have to come down again.
  #6
Old September 18th, 2018, 09:23 AM
melsg5's Avatar
ADMINISTRATOR
Not sure what kind of float you have, metal or a plastic but both types can have issues. The metal can develop leaks and the plastic can become porous. The metal one you submerge in some water and check for air bubbles.
__________________
Reply
Tags
flooding, hot start, rochester
