Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac Grand Prix Forum
Advertisements
cars connected social network
Notices
Pontiac Grand Prix Forum Discuss topics regarding the Pontiac Grand Prix.
Pontiac Forum: Sweet new ride ..
Reply
  #1
Old October 11th, 2018, 04:05 AM
AmotoXracer AmotoXracer is offline
Junior Member
AmotoXracer is on a distinguished road
Sweet new ride ..
Just bought a 2007 Grand Prix GXP with 37k miles. Its pretty sweet. These cars are getting hard to find with low miles.
So there's a whirring noise, like a small electric motor with the key on, engine running, hvac off. Its in the interior and sounds like a fan motor for a laptop computer or something. Maybe like an interior temp sensor or something. Anyone know what this is ?
If someone has ever adjusted front camber to zero, and can speak to whether or not you have to elongate the bolt holes in the struts, then id like to know that. These cars came with Bilstein struts, or at least this one did, so I'm hoping I can just align it.
Anyone ever change the GPS radio out for the normal Monsoon cd player ?
  #2
Old October 11th, 2018, 04:07 AM
Junior Member
Wth I cant figure out how to upload a picture .. .
  #3
Old October 11th, 2018, 10:04 AM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
FAQ will show how to load pictures.
The interior HVAC circulating fan runs all the time when the engine is running.
why are you trying to set camber to zero? The spec. I found is -1.15 + or - .70
__________________
1971 GTO 455 HO Ram Air
  #4
Old October 11th, 2018, 04:46 PM
Junior Member
Ok well I hear something for sure. Maybe there's a fuse I can pull, otherwise ill have to find it and unplug it. I don't suppose you have a wiring schematic do you ?
I want camber to zero for two reasons. One is it handles better with camber set at zero, and two is tires wear better. You can really feel the negative spec the way its set up now. Too much driver input is required.
  #5
Old October 11th, 2018, 05:10 PM
melsg5's Avatar
ADMINISTRATOR
you can pull the fan motor fuse to check if that is the source of the noise but if so you need a new fan motor.
Actually cars set for the track use negative camber so when going in a turn the loaded/outboard tire has a a larger contact patch. You can look for top plates that permit adjustment out of factory specifications.
Driver input sounds more like too much caster.
__________________
  #6
Old October 11th, 2018, 05:43 PM
Junior Member
I don't want a track set up. The honest reality is this car is never going to go through a turn hard enough to roll the tire over onto its shoulder. I'm going to be using it primarily for highway travel, which means straight line stability is what I'm looking for.
I'm going to get to the bottom of this spinning fan thing. Is it under the dash pad ?
  #7
Old October 12th, 2018, 10:45 AM
melsg5's Avatar
ADMINISTRATOR
As I noted above those are the factory alignment specs for the Grand Prix so it may not go all the way to zero you will have to try.
This video gives you an idea of where the blower is
https://www.youtube.com/watch?v=G_KPwEI-Pes
__________________
Reply
