Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac 6000 Forum
Advertisements
cars connected social network
Notices
Pontiac 6000 Forum Discuss topics regarding the Pontiac 6000.
Pontiac Forum: dtc 42
Reply
  #1
Old July 28th, 2017, 11:01 PM
harley42 harley42 is offline
newb
harley42 is on a distinguished road
dtc 42
I have the shop manual. DTC code 42 , est - electronic spark timing error.
Following the flow chart leads to the ign. module, or ecm, the computer. I have replaced both. It has quit running after warm up as a 1/2 mile. I tested the injectors for ohm and replaced one that read 5 ohms.It starts and run very rough. The last four times it quit it wouldn't restart. Fuel pressure is 42, the correct reading. I have spark using a tester on one plug. The next step is hooking up my Hantek scope and tablet.
  #2
Old July 29th, 2017, 10:37 AM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
found this article that gives you some other things to check, using google "dtc 42 causes" will give you more.
http://www.batauto.com/threads/g-m-%...code-42.14056/
__________________
1971 GTO 455 HO Ram Air
  #3
Old October 6th, 2018, 09:20 PM
newb
update on 2'8 6000 mpi. It starts and will break up at 400rpm. Both bank plugs are black, super rich condition. I replaced the injectors, the pressure regulator, the timing chain and gears. Cyl pressure is 110, on #6, i assume the rest are similar. Only code is 42. The plugs are new 4 iridium and 2 older delco. Cat and complete exhaust replaced.
  #4
Old October 7th, 2018, 09:52 AM
melsg5's Avatar
ADMINISTRATOR
Why would you assume what the compression is on the other cylinders when 110 is so low a reading?
__________________
Reply
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
