Sign up to remove ads. We'd love to have you amongst our ranks! Just Click here!
pontiac forums   pontiac forums
Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac LeMans Forum
Advertisements
Pontiac LeMans Forum Discuss topics regarding the Pontiac LeMans.
Pontiac Forum: Power seat relay
Reply
Thread Tools
  #1
Old July 23rd, 2018, 06:47 PM
Johnnyj Johnnyj is offline
Member
Johnnyj is on a distinguished road
Power seat relay
My 72 Lemans originally had bench seats. I am presently installing poweseats from a GTO. I purchased the relay from OPGI but can figure out where the wires go.
I have installed other relays in the past. This relay is designed different. Two of the sets of prongs in the front are one piece?? If you look at the relay under OPGI you'll
Understand. I called OPGI , they said they have no idea hoe it goes. Can someone explain how the wires go, or should I just use a normal relay for each. Seat?? Thanks
  #2
Old July 24th, 2018, 10:31 AM
melsg5's Avatar
melsg5 melsg5 is offline
Senior Member
ADMINISTRATOR
melsg5 is on a distinguished road
The wiring diagrams for the seats are in the 1972 factory Pontiac Service Manual in the Chassis Electrical section. You can try google to find some Pontiac power seat wiring diagrams.
__________________
1971 GTO 455 HO Ram Air
  #3
Old July 24th, 2018, 11:24 PM
Member
I looked at the wire diagram in the 72 service manual. It does not show how to. Attach wires to relay. The relay as no numbers on it, and is not like a normal relay.
I'll keep looking. Thanks for the info, I appreciate any help I can get.
  #4
Old July 25th, 2018, 09:51 AM
melsg5's Avatar
Senior Member
ADMINISTRATOR
You did look at the A & G Series Power Accessories Schematics?
When you say attached, they were originally attached with a wire harness that had a plug.
The Ames part number for the drivers side is M07020.
The ground wire is M07295.
__________________
  #5
Old July 27th, 2018, 10:38 PM
Member
Ok, I'll check into that. Obviously I'm no expert!!
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2019, vBulletin Solutions Inc.
pontiacforum.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacforum.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
Miss the Pontiac G8 GT? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
