Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac LeMans Forum
Advertisements
cars connected social network cars connected social networking app for ios cars connected social networking app for android
Notices
Pontiac LeMans Forum Discuss topics regarding the Pontiac LeMans.
Pontiac Forum: 1977 Can Am restore or modify?
Reply
  #1
Old September 10th, 2017, 02:50 PM
automech01 automech01 is offline
Junior Member
automech01 is on a distinguished road
Just bought a Can Am with 39,000 original miles but it has a non original stock looking 71 455 engine. would i hurt the value by modifying or leaving it stock? It already has a 041 cam and Ram Air manifolds.
  #2
Old September 11th, 2017, 09:46 AM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
You no longer have the original engine so making more mods will not effect the value. You are sure about the 041 cam? They are not exactly friendly to stock automatics and require a decent rear end gear to perform.
__________________
1971 GTO 455 HO Ram Air
2017 Mustang GT
  #3
Old September 11th, 2017, 10:02 PM
Junior Member
Its a lunati Duration @ .050 (Int/Exh): 230/230 Gross Valve Lift (Int/Exh): .490/.490 LSA/ICL: 110 very similar. I want to put a holley sniper efi system on it.
  #4
Old September 12th, 2017, 10:16 AM
melsg5's Avatar
ADMINISTRATOR
sounds like a good plan, good luck and keep us posted on your progress
__________________
2017 Mustang GT
  #5
Old September 13th, 2017, 12:36 PM
Junior Member
Thanks has anyone removed the door hinges off of a 77 before? trying to remove the door to replace the hinge pins and the upper hinge has a spot weld on it?
  #6
Old September 13th, 2017, 02:34 PM
melsg5's Avatar
ADMINISTRATOR
You are trying to remove the door as a complete assembly?
Doesnt the hinge assembly bolt to the body and door?
__________________
2017 Mustang GT
  #7
Old September 13th, 2017, 03:23 PM
Junior Member
got the door off from the hinge it had a tack weld on the top hinge. From the factory?
  #8
Old September 14th, 2017, 09:52 AM
melsg5's Avatar
ADMINISTRATOR
havent seen that, did you compare it to the other side?
__________________
2017 Mustang GT
  #9
Old September 14th, 2017, 11:46 AM
Junior Member
not yet doing the other side today
Reply
Copyright ©2000 - 2017, vBulletin Solutions Inc.
