Sign up to remove ads. We'd love to have you amongst our ranks! Just Click here!
pontiac forums   pontiac forums
Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac G8 Forum
Advertisements
cars connected social network
Notices
Pontiac G8 Forum Discuss topics regarding the Pontiac G8.
Pontiac Forum: Center Dome Light front and rear do not work after LED failure.
Reply
Thread Tools
  #1
Old June 12th, 2014, 12:14 PM
Umdaman Umdaman is offline
newb
Umdaman is on a distinguished road
Question Center Dome Light front and rear do not work after LED failure.
2009 G8
Hi, I installed some LED lights for the Dome lights and the map lights. The center dome light LED appeared to have overheated and de-soldered itself and fell down into the enclosure. After that happened I noticed the rear dome light doesn't work along with the front after fixing the bulb. But the map lights still work. I checked every fuse in the rear and front. I have not checked any fuses in the engine. Pin 1 & 2 which is for the center dome light has NO POWER at all when the door is open.
I have the interior lights schematics. It looks like the 1597 PK/BK wire is the bad one. It shows it going to a fuse labeled CF5 or CF6 its hard to read. But looks like the Map lights are also on the same fuse..... After the fuse it goes to the computer Pin #18.
Any ideas? I hope the computer didn't get fried for that circuit.
  #2
Old June 12th, 2014, 01:16 PM
melsg5's Avatar
melsg5 melsg5 is online now
Senior Member
ADMINISTRATOR
melsg5 is on a distinguished road
Did you look in the owners manual section that covers fuses and their purpose and use a voltmeter to check for power going to the fuses
http://www.vadengmpp.com/owners-manu...Pontiac-G8.pdf
  #3
Old June 17th, 2014, 11:41 AM
newb
Yes I'm pretty sure I know how fuses work and their purpose.
Fuse F11 Interior Lamps
But when removed Map lights still work. So I don't know what Interior lamps they are talking about in the manual. Tested F11 and has 12v.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.11
Copyright ©2000 - 2018, vBulletin Solutions Inc.
pontiacforum.com recognizes that "Pontiac", it's logos and various model names and numbers are registered trademarks of the General Motors Corporation. These terms are used for identification purposes only. pontiacforum.com is not affiliated in any way with the General Motors Corporation, Pontiac or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2017 pontiacforum.com. All rights reserved.
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Pontiac? Check out your options at the links below:
Miss the Pontiac G8 GT? Believe it or not, Kia may have something for you. The Kia Stinger is a large sport-oriented hatchback sedan in the mold of the Audi A7.
