Go Back   Pontiac Forums > Pontiac Car Forums > Pontiac G6 Sedan / G6 Coupe Forum
Advertisements
cars connected social network
Notices
Pontiac G6 Sedan / G6 Coupe Forum Discuss topics regarding the Pontiac G6 Sedan and G6 Coupe.
Pontiac Forum: Strange Noise
Reply
  #1
Old September 13th, 2018, 10:40 AM
whitehawk97 whitehawk97 is offline
newb
whitehawk97 is on a distinguished road
Strange Noise
The only way I know how to describe this noise is it sounds like a cricket. I only hear it during low to moderate acceleration. I'm not saying it isn't there under hard acceleration, but I can't hear it then. I can not determine which end of the car it is coming from.
It's a 2009 G6 GT convertible with the 3.5ltr auto trans.
Any ideas? Heard this too?
Thanks in advance.
  #2
Old September 13th, 2018, 10:56 AM
melsg5's Avatar
melsg5 melsg5 is offline
ADMINISTRATOR
without you being able to narrow it down to which end or side of the car, telling you over the internet what the cause is, is highly doubtful. It could be brakes, wheel bearing, CV joint, accessory drive belt, etc. Find a local repair shop you trust and have someone ride with you so that you can point out the noise.
__________________
1971 GTO 455 HO Ram Air
  #3
Old September 24th, 2018, 05:16 AM
newb
I believe I can eliminate the brakes, wheel bearings and CV joints, as the noise remains the same even when I shift the car's weight from side to side on acceleration. I thought about the idler pulley/accessary belt, but the pitch of the noise never changes with RPM's. My concern is it may be coming from the transmission. Any thoughts?
  #4
Old September 24th, 2018, 09:24 AM
melsg5's Avatar
ADMINISTRATOR
You still cannt tell which end of the car or which side? How is "shift the car's weight from side to side on acceleration" a valid way of checking wheel bearings, brakes, and CV joints? Did you remove any of the wheels to check the brakes? Did you jack up the car and check for excessive play in the wheel bearings? Did you check the transmission fluid level and condition, if you dont have a dipstick it has to be raised level and the fill plug removed.
__________________
Reply
