02 won't start.
Ohio
When the car first died I check to see if I was getting both gas and spark. Had spark but no gas and could not hear fuel pump kick on. Replaced fuel pump got gas but no spark. Checked power to ignition control module was good. Checked both voltage and ohms from crankshaft position and both was good. Replaced the ignition control module, all 3 coil packs, plugs and wires and still no start. I am now stumped, any suggestions?
