'03 vibe disc brake conversion.
Tgotr
My wife's 03 vibe suffered some damage which resulted in the driver's side rear drum to suffer damage. I figured if I have to replace the drum, why not perform a drum to disc conversion.
I know the gt model had discs all around. What do I need to get so I can successfully put discs on the back?
20,326
135
63
Backing plates, hubs, rotor, caliper, seems like the axle, master cylinder. Look at www.gmpartsdirect.com and look at all the different parts between the GT and what you have.
Tgotr
Looks Like all I have to source is a backing plate, looks like the hub and bearing are the same. It seems disc all around was an option on the base trim, and would be an easier job as I don't have to press in bearings and the hub into the axle like I would if the rear wheels were driven like on the GT.
