09 Vibe GT Engine Replacement HELP
Weimarman
I have a 2009 Vibe GT 2.4l 2ZFE ruined motor. Want to do a direct swap with a 2015 Scion XB 2.4l 2ZFE with 63,000 miles. Will it match up? Thanks for any Help!!
21,659
216
63
Since Pontiac ended the Vibe in 2010, i think you should post a question on a Toyota forum as to what changes, if any, Toyota made to the engine between 2009 and 2015.
Weimarman
Update: Installed 2015 Scion XB 2AZFE. Perfect fit! No modifications needed. No check engine lights.
