17 inch tire sizes
18,758
27
48
Can you measure the amount of additional clearance you have inside and outside? From that I can figure out what size will fit without changing the overall tire diameter. I assume you want to keep the same diameter to prevent speedometer error.
Grumps
Inner is half inch from strut mount.
Outer has 4 inches at top of tire and 3 inches left and right of tire.
Possibly I need to go to a narrower and taller tire?
18,758
27
48
In the rear you can go to a 225/45x17. Anything wider you will need wheels with more negative wheel offset to push the wheel further out.
