1965 389 tri power engine
Duff
What's the going price for a 1965 YG code 389 tri power engine that's complete and still original and runs good? The seller wants $2500, any idea what body style it came from? Thanks!
20,326
135
63
YG is a 338 HP engine used with an automatic transmission in 1965. Not body specific Make sure the casting number is 9778789 since the code was used in later years. You need to check head numbers and carburetors also.
Duff
Thanks for the info. I'd like to buy it, clean and paint and use it as a display piece, maybe down the road install in a car. I'f all the numbers jive, I'm going to offer $1500, if it were coded for a 65 GTO, then it'd bring more $$$.
20,326
135
63
There is no way of knowing if it was in a GTO and the intake and carburetors alone are worth more than 1k.
Duff
The last tri power I bought was a complete and original unit from a 1966 GTO, paid $850 for that one about 4 years ago. I don't think a vacuum 65 unit would bring a $1,000. I'm going to make an offer of $1500, only because it runs and has never been apart. There's another guy interested in it, so the seller may get the $2500. I was hoping to determine what body style, but at least I now know it 's from an automatic car. I'll post pictures if the deal goes thru. Thanks!
