1966 Catalina resto
robmiller
I just bought a 1966 Catalina 2-door base, or at least I'm assuming it's a base since it doesn't have any louvers on the sides. I'm going to be looking for a lot of things for it. I wonder if anybody can offer some suggestions.
1. I need a new dash pad, or to have the old one recovered.
2. I need the top center air conditioner register/vent above the radio area.
3. Would like to buy new foam seat pads (bench) for the front.
4. Need the correct radiator and fan shroud.
5. Hood hinges -- definitely driver's side, possibly also passenger side. I'd buy a pair if available. The springs are present.
Does anybody know what parts from a GTO 2-door will fit the Catalina?
20,497
141
63
Generally speaking A body (tempest) and B body (Catalina) do not interchange.
Try frankspontiacparts.com for OEM and Ames Performance and Original Parts Group for reproductions.
Good luck with your project.
robmiller
Interesting. Since the Impala was a B-Body, I wonder if any of the Impala parts will fit the Catalina? Any experience on this? There seem to be a lot more Impala parts available than for the Catalina.
20,497
141
63
GM divisions were separate in the 60's, again very little interchangeability
mobileparts
Member
63
The comments you received were 100 % correct. Full Size Pontiac is all by himself... No full size other G M with a rare exception... And no GTO /Tempest / LeMans with a rare exception....
The Great News is I have MOUNTAINS of NEW and N.O.S. parts for your big boy.
But nothing on your list --- I am strictly NEW Mechanical parts --- brakes , front end, ignition, electrical, fuel pumps, water pumps, motor mounts, transmission mounts, quality tune up parts, and a whoooooooole lot more....
You are welcome to always simply call me --- Craig --- 516 - 485 - 1935.....
Congratulations on your new toy !!!!!
robmiller
Thanks very much — I’ll put your number in my book. I have yet to begin and there will be a lot of things I need so I’m sure we’ll be in touch!
44
May hav items such as hood hinges & radiatior
In Lanaing Michigan
Omishjon4@gmail.com
robmiller
Does anybody know if the OPGI 2+2 interior trim kit will work on the base? I'm assuming there's nothing structurally different about the car so it should fit? I don't see a kit available for the base model. Any reason I shouldn't go that way?
20,497
141
63
Who makes the interior they sell Legendary or PUI, call which ever manufacturer directly or call both of them, they both do retail sales.
