1967 Catalina problems
poonshu
I have just pulled my engine this weekend and changed the oil pan because of a crack in the old one the new one I recieved had a plate that I had to remove for the new one to fit. I have replaced everything and now my engine squeals and my car wont shift in gear I have put all fluids back into the car and I dont know where to go from here. Please Help!!!!!
20,319
135
63
Are you saying you removed the engine from the car to change an oil pan? Cannt you tell from where the noise is coming? If you removed the engine it sounds like either there is a problem with the shift linkage or when you put the engine in you didnt correctly reconnect the torque convertor to the flex plate.
