1967 GTO 400 CID performance differences
dtox
Hi,
can someone answer my question? Is the 400 CDI block at the 67 GTO in the three performance stages identical and the performance differences arise only by the intake and carburetor? Or are there other components responsible?
Regards
Daniel
19,442
67
48
I am assuming you mean the 255 HP engine which used lower performance heads and camshaft then the 335 HP engine. The 360 HP used a different cam than the 335 HP. All three had different distributors.
dtox
Hi melsg5,
exactly, thank you! Would it be better to change the engine/buy another car with the 335hp engine or it is meaningful to change the parts?
19,442
67
48
You havent stated what you have or how you determined what it is.
Can you provide some details?
dtox
Sorry. I have to decide between a 255hp GTO in good shape with some little things to fix or a 335hp GTO which i would prefer because of the engine but much more to do. Of course there is also a gap of 10k between the two cars.
19,442
67
48
Yes, I unfortunately had a 1968 GTO with the 265 HP engine. At the time my father was shopping for a new car and you can imagine how excited I was that the GTO was cheaper than the Oldsmobile Cutlass which was the other contender. The damn salesman convinced my father that getting the 2bbl low compression engine that ran on regular gas was the way to go, it was a no cost option. That car was a dog, between the low power and a 2.78:1 rear ratio it was incredibly slow. Unless you are considering to buy the 255 HP GTO for it's "collectiblity", move on to the much more common 335 HP version.
dtox
Thanks for your support. Helps to choose the right one. I will post some pictures when i bought the car.
