1969 Grand Prix heater control panel vacuum tubes routing question - - -
69-Gp-Alex
Hello group!
My question regarding heater control vacuum tube colors and routing.
I am drawing vacuum to the water valve, (which is keeping the valve open), when the control panel shut off.
Wondering if the tube colors are in their correct locations or if the rotary switch is not blocking the correct passages.
Let me know
Thanks!
Alex
20,038
110
63
why would the hoses not be in their correct positions?
Did you just buy this car?
If the control panel is in the off position why are you concerned whether the valve is in the open or closed position?
With the engine running and the AC on and turned to full cold is the valve closed?
69-Gp-Alex
Hello Mel,
- "why would the hoses not be in their correct positions?" Did you just buy this car?
Going through and undoing-correcting from the previous ownership. A/C compressor pump and related is gone,
hoses and condenser core are present.
- "If the control panel is in the off position why are you concerned whether the valve is in the open or closed position?"
Having the valve closed shuts off the hot water flow to the heater core thus keeping the cabin comfortable on hot days.
I did some mountain driving this past week, outside temperature was high 80's, now compound that with full on heat due
to the water valve being open, (heater box closed and blower motor is off).
My thought is.. does the entire heating and cooling system have constant vacuum pressure with the panel off?
If so, then I need a water valve that is open at rest. When installed, the vacuum pressure holds the valve closed
until I select heat or A/C? Have not gotten this far to prove yet.
20,038
110
63
You need to purchase a copy of the 1969 factory Pontiac Service Manual.
I have a copy of the 1970 and section 1A of the manual has the vacuum line routing from the control assembly.
What is unclear to me is what did you have the controls set for when you went on the drive?
Was the temperature set for full cold and was the selector lever set for AC or BiLevel?
