1970 Lemans Sport wheel and tire size
PaWalt
Racking my brain deciding on correct tire and wheel size. Id like to go 15x7 or 8" in the front and 16x8 or 9's in the rear. Any suggestions with some pics please???
21,075
172
63
well you are only mentioning wheel size not what tire size you are considering. You also should be aware that in 15" tire/wheel size you are extremely limited in selection and in quality of tire. In addition the 16" category inst doing all that well either.
So I would be looking at 17" all around, 8" width is fine, 9" you have to pay more attention to available space so you have to look at back spacing and offset.
Tire size you can probably go to 245/45x17 in the front and 255/45x17 in the rear. Whatever you do you should work with a tire/wheel supplier willing to test fit your selection.
G
G-398456
I have a 1970 Lemans and I am planning 17x9s with a 275 tire on the rears. Has anyone run that in stock fenders?
21,075
172
63
Ames Performance sells Ralley II wheels in 17x9 with a 5" backspace. I found this chart which seems to indicate it will fit.
GTO Wheel Size Chart
5x120mm (5x4.72in.) Bolt Spacing, 48mm Offset (Stock 17x8's), 69.5mm Center Bore, 6" BS
WIDTH..........OFFSET............WIDTH OF TIRE
7.0...............+26/+65.............215/225/235
7.5...............+33/+61.............215/225/235/245
8.0...............+39/+55..............225/235/245
8.5..............+45/+48..............235/245/255
9.0.(MAX).........+48................245/255
REAR ONLY
8.0................+36/+65.............245/255
8.5................+42/+65...............245/255
9.0.................+48/+65...............255/265/275
9.5................+55/+64...............265/275/285
