1972 Pontiac Ventura II
ventura72'
Hello All
Does anyone know if it is possible or feasible to take a rear end out of 1988 Chevy Camaro and put it into a 1972 Pontiac Ventura?
Thanks
zachludwig
Ohio
88 camaros use coil springs I'm pretty sure so you'd have to cut off those spring mounts and weld on new ones for the leaf springs and the 88 also uses control arm/trailing arms whatever they're called so those would need removed at least to fit under the body. It is do able but not just a straight up swap over. The 1st gen f bodies will fit under your x body and pretty sure 2nd gens will too (direct fit).
