1973 pontiac firebird drop spindles?
mikki1211
anyone got any info on how and where to measure to find out that if my car has drop spindles if how much they are dropped?
any info at all would help me out =)
21,860
235
63
This is a 2" dropped spindle, note the location of the hub with relation to top and bottom of the spindle.
The rocker panel height below the front edge of the door is approximately 8.07" with full fuel tank.
mikki1211
thank you, will check that tomorrow.
just found this image on my computer of my spindles. not sure if this can tell anyone something about spindle hight.?
21,860
235
63
Look at them compared to the 2" drop in the link, yours are stock.
21,860
235
63
A dropped spindle lowers the height of the vehicle by raising the position of the hub on the spindle. If you look at the link I gave you and compare the position of the hub of yours compared to the link you will see your hubs are on the bottom of the spindle, thus they are not raised and you do not have dropped spindles.
Why do you even think they are not stock?
