1974 Grand Prix 400 performance issues
Oliverd642
Hey all, wondering if I can get any advice.
I have a 74 GP with a 400 motor, the car pulls really well from a stop but feels under power at speed. It does not feel like a 220bhp vehicle. I’ve recently changed the cap, rotor and plug wires.
It does not hesitate, it just picks up speed really slow say from 30mph +
Sometimes it will kickdown hard and fly like a rocket other times it will kickdown and slowly get up to speed.
*new air filter
*new ignition cables, rotor & cap.
*64,000 original miles
*original Rochester qjet carb
*true duel exhaust, no cats
*running 98 octane European fuel
*newly serviced trans, engine and diff oil
Small exhaust manifold leak, small oil leak from engine.
Runs really well otherwise
21,061
169
63
First we have to determine which transmission you have. It could be Th400 or a Th350. How many cables do you see attached to the throttle linkage of the carburetor?
If you only see the gas pedal throttle cable you have a Th400.
If you see a second cable you have a Th350.
The Th400 uses a switch attached to the gas pedal to control downshifting along with a vacuum line from the engine connected to a modulator on the transmission case.
The Th350 uses the second cable to control downshifting along with the vacuum line going to the modulator.
So which transmission do you have?
Oliverd642
Forgot to add that part! I have a th400 trans. Where exactly is the vaccum line?
21,061
169
63
You should see it running on the passenger side of the engine down to the transmission.
Also make sure the wire on the gas pedal switch is connected at the switch and at the solenoid on the drivers side of the transmission case.
Oliverd642
Okey thanks I will check today after work
