1978 Catalina stored since 1991 checking the engine before starting
Bigpat13601
I just acquired this 1978 Catalina with 55k original miles it has the 4.9 301 with the 2-barrel carb, it had been stored in a garage since December 1991. The mice had made it home for a very long time in the air cleaner under the air cleaner and over the hood insulation.
after removing about 99% of it I started to check things out the oil was full, but the radiator was half full the motor turned over by hand and a breaker bar.
My first concern is the block and the freeze plugs and how to check to make sure everything is still in place and not cracked.
Ideas and advice needed
Thank You
20,846
162
63
Drain the oil and remove the filter and look for signs of water/antifreeze in the oil. Antifreeze and oil make a substance that is creamy brown in color. Refill the cooling system with water and rent a pressure tester to check for leaks. With fresh oil and filter in place you also buy a hydrocarbon tester that will check the coolant for signs of exhaust gas entering the cooling system. Dont forget to change the transmission filter and fluid and get new tires. Good luck.
Bigpat13601
Thank you
My big worry is the winter weather that is on it's way. The car is going from a garage to outside storage exposed to the elements. if I happen to get lucky and no leaks there must be a lot of rust and scale in the system that will have to come out sometime. would I run the engine up to Temperature with the water? sorry for the dumb questions but my local garage closed and with the new vehicles this is all new to me. Thank you again
Classics Fan
Anacortes, WA
A true barn find! Fun! You’re doing the right thing asking good questions. Good luck and don’t stop asking and learning.
20,846
162
63
buy some Prestone cooling system flush and follow the directions. Obviously after flushing it you need to use either a 50/50 mix of antifreeze and distilled water or a premixed antifreeze.
Classics Fan
Anacortes, WA
Be sure to use distilled water as noted, not tap water to prevent mineral deposits from forming in the radiator. Hopefully the corrosion your radiator core likely has from being exposed to air by not being filled is minor.
Bigpat13601
Hi
I drained the Oil and removed the Filter, my plan was to drop the Oil pan but the way the weather was going and I would have to lay on the ground to get into it. So while I was under the car I removed the transmission pan and filter it was dirty.
while I had the front end up, I pulled the plugs and turned it by hand a few times it moved freely but the starter clicked once and that was it the starter crapped out. The gas gauge read a half tank, so I tried to siphon what was left in it out no luck some rust on the bottom of the tube no gas.
So, I thought dump some gas in it and see what happens pumped the gas a couple times turned it over nothing put some gas in the carb and a couple of shots of starting fluid and it took off.
20,846
162
63
Good to hear you brought it back to life
cammerjeff
Active member
625
27
28
Belleville MI
Great news, good luck with it, I have a soft spot for 78 Catalina's I have a Safari and a Safari parts car at the moment. I always preferred the roof line of the 77-79 coupes over the the 80-82's. Post some more pictures when you get a chance.
Bigpat13601
I just wanted to say thank you to everyone for the advice. I thought I share some photos after doing a quick clean on the outside of the engine, the green tape on the plug wires is how I marked them so I would not get them crossed after pulling all of them to cycle the engine before trying to start it.
the drivers seat has some damage no big deal though the floor cover has faded some.
